Scratch Stock Holder - Router Forums
 16Likes
  • 9 Post By gmercer_48083
  • 2 Post By JOAT
  • 2 Post By Stick486
  • 2 Post By Cherryville Chuck
  • 1 Post By Stick486
post #1 of 5 (permalink) Old 01-12-2020, 12:42 PM Thread Starter
First Name: Gary
Default Scratch Stock Holder
A simple idea that works so well.https://www.finewoodworking.com/2008...-scratch-stock
Using a piece if hardwood 1" x 1" x 4" with a saw kerf cut 1/2" deep in the center, it will hold a modified 1/2" bandsaw blade that can be used to put a nice bead on the edge of wood quickly. I liked it so well I decided to draw it in Sketchup.
Name:	Garys Scratch Stock Holder.jpg
gmercer_48083 is offline
post #2 of 5 (permalink) Old 01-12-2020, 01:23 PM
JOAT's Avatar
First Name: Theo
I've done something similar for years. I use a small length of 1/2" plywood, around 1/2" or so wide, bandsaw a cut into one end. Then glue the broken bandsaw piece in the slot. Very handy tool at times. Not especially pretty, but that wasn't the point.
MYB and jj777746 like this.
JOAT is offline
post #3 of 5 (permalink) Old 01-12-2020, 01:38 PM
Great idea...
I'd add a nutsert for the bolt and a locking nut...
Finer ''hard'' hardwood w/ brass aesthetics???...
Soften the edges???
Use Sawzall blades in lieu of bandsaw???...
Grind your own profiles???
post #4 of 5 (permalink) Old 01-12-2020, 02:12 PM
I`ve been planning on making one ever since I saw the article. I think I would make it in 3 pieces to simplify it though and that would allow to put a t-nut or threaded insert like Stick said on the end of the piece where the rod would hold the cutter. So it would be one piece with that, a stop block on the other side of the cutter gap, and then a long piece on top of the two smaller ones to join it all together. I`ve also seen one where the slot for the cutter is cut longways on the piece instead of crossways and there are bolts on either side of the cutter to squeeze the gap tight to hold the cutter. The end of the rod makes a handle and the scratch stock is held at 90* to the work.
post #5 of 5 (permalink) Old 01-12-2020, 02:29 PM
make the saw kerf to depth as required..
change the block dimensions to suit yourself...
Kant the kerf to suit a need???...
dual kerfs, dual scrapers, one holder???...
Kanted and perpendicular kerfs in the same holder???
I think the long side of the block to the work is better for ''control''....
jj777746 likes this.
