making a cutting board with an initial in center of field - Router Forums
 14Likes
post #1 of 18 (permalink) Old 01-17-2020, 02:22 PM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default making a cutting board with an initial in center of field
Advice appreciated please.
I'm thinking of making a face grain cutting board with an initial in the field.
Thought process:
stack 2 pieces on top of each other and bandsaw out the initial then swap the cutout for each other. The edge of the initial will be one the edge of the board, so no starter hole will be required. BUT the internal area of the initial is my dilemma. How do I get that to line up with the rest of the board? Don't forget there is a loss of material due to the bandsaw blade cut.
thks
smitty
Name:	cutting borad initial.jpg
smitty10101 is offline
post #2 of 18 (permalink) Old 01-17-2020, 02:36 PM
cut it as an inlay as you would say a butterfly......
even if it's a though and through...
jw2170 and Al Robins like this.
post #3 of 18 (permalink) Old 01-17-2020, 02:43 PM Thread Starter
First Name: smitty
got the inlay idea, but how do I get the "inlay" to fit EXACTLY into the recess?
As I typing the gray matter is going--- the initial inlay will be of a thinner material than the rest of the board but the fit is still giving me "fits"---pun intended.
will have to experiment with the inlay collar & bit.
BTW what size router? 1 1/2-2 hp or a trim router?
3hp is probably overkill.
thks
smitty
post #4 of 18 (permalink) Old 01-17-2020, 02:45 PM
form up the letter w/ multiple (as in many) end contrasting grain pieces and inlay it...
post #5 of 18 (permalink) Old 01-17-2020, 02:48 PM Thread Starter
First Name: smitty
just for clarity---in case someone searches this topic later--
it's a face grain cutting board not an end grain one.
will try the inlay this weekend.
will let you know the outcome.
thks
smitty
jw2170 likes this.
post #6 of 18 (permalink) Old 01-17-2020, 03:39 PM
thks
smitty
the inlay can be any depth..
for a cutting board; 1/3rd the thickness will be way adequate...
a trim router will give you better control...
a horse and a half is getting serious..
but there's nothing stopping you from Tim Allen'ing it...
jw2170 likes this.
post #7 of 18 (permalink) Old 01-17-2020, 03:40 PM
thks
smitty
make the letter face grain???
post #8 of 18 (permalink) Old 01-17-2020, 09:06 PM
JOAT's Avatar
First Name: Theo
Not interested in making cutting boards myself, but awhile back got curious, because of the various posts on the subject. So, did a search, using something like "cutting board designs" as a search phrase. Wow. Talk about some inspiration, some of those boards looked like art. I mean your mouth will drop open when you see some of those designs. Give it a shot.
JFPNCM likes this.
JOAT is offline
post #9 of 18 (permalink) Old 01-17-2020, 09:50 PM
I have never done this, but I have done the stacking 2 boards of different colors and cutting them out then swapping parts. There is a lot of sanding to get them to fit exactly perfect. Remember on the letter "S" the outside cut out on the curve will get bigger and the letter itself will get smaller on the outer edge, as you sand, thus you may have to fill in the difference by banding the outer letter with a thin strip.
Myself I think I would make 2 boards and cut the "S" out first and sand the edges smooth, then lay it on the second board and mark around it. Then cut the second board a tad smaller, to give you some material to take off to fit the letter into.
Good luck, be sure to take some pictures of how you decide to do it. A real challenge, maybe mock up a couple before you do the final project.
Herb Stoops is offline
post #10 of 18 (permalink) Old 01-18-2020, 12:34 AM
JFPNCM's Avatar
First Name: Jon
As Herb said, we really would like to see the step by step photos.
Jon
JFPNCM is offline
