Jewerly Box w/ problem banding - Router Forums
 5Likes
  • 3 Post By difalkner
  • 1 Post By Stick486
  • 1 Post By TwoSkies57
post #1 of 5 (permalink) Old 01-29-2020, 01:40 PM Thread Starter
oldprinter1468's Avatar
First Name: Berry
Default Jewerly Box w/ problem banding
I started this long ago and because of the problem it sat on a shelf in the closet. But I've decided to try and fix the mess. I looking for suggestions. This project is based on plans from Woodsmith Magazine. The central inlay I purchased from Constantine's. The banding around the inlay I cut. I think what happened is that the groove wasn't deep enough and when I sanded the top I went thru in an area where the banding was a bit thinner. So.... 1) should I replace the whole strip or just the section that's bad? 2) should I cut out the banding to be replaced with a chisel or router? 3) I'm worried that I may damage the inlay and then I might as well put it in the fire box.
I'm not sure it matters but the banding is maple and the rest of the top is walnut. The central inlay comes right up to the banding. Under the inlay it's pw. Thanks for reading.
Name:	Jewerly Box 76.jpg
Name:	Jewerly Box 82.jpg
We all do better, when we all do better.
oldprinter1468 is offline
post #2 of 5 (permalink) Old 01-29-2020, 02:18 PM
JOAT's Avatar
First Name: Theo
I'd say go with whatever way you are most comfortable with.
JOAT is online now
post #3 of 5 (permalink) Old 01-29-2020, 03:10 PM
difalkner's Avatar
First Name: David
I would replace the entire strip. You'll spend far less time on that than you would if you tried to splice or blend in a new section and it will look better when you're finished. This, to me, is one of those 'cut your losses' moments where you just go ahead and bite the proverbial bullet.
As for which method to use I would go with what Theo said - whichever way best suits you and your experience.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 5 (permalink) Old 01-29-2020, 06:39 PM
I'd replace the strip also...
and I'd use a router plane to do it...
graeme.c.payne likes this.
post #5 of 5 (permalink) Old 01-29-2020, 06:47 PM
TwoSkies57's Avatar
as mentioned... just go ahead and replace the entire strip...you'll be ahead of the game. AND be prepared to replace the remaining 3. There may be more color difference than you'll like when compared to the remaining 3 sides. As for method.what ever floats your boat. Router plane would work very nicely!
Stick486 likes this.
Skipper the Penguin
TwoSkies57 is offline
