Harbor freight rant - Router Forums
 44Likes
post #1 of 31 (permalink) Old 02-28-2020, 08:06 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Harbor freight rant
Today I went to Harbor freight needed a new bench grinder checked Craigs list cheapest was $40 1/3 hp. Harvard freight had a 1/2 hp. for $40 with
20 %coupon. At the register fine print says central machine excluded GRR. Still feeling good compared to craigs list. Got home opened the package
found the guard bent to point wheels will not turn. Bent worse than I want to fix about 1/4 inch. Took the guard cover off three screws. Did the job . Now have to drive 40 miles back and forth to return. The wheel on that side wobbles bad also. I think was the last one on the shelf.
newbie2wood likes this.
roofner is online now
post #2 of 31 (permalink) Old 02-28-2020, 08:09 PM
got to test scrutinize their stuff before you get to the cash register...
post #3 of 31 (permalink) Old 02-28-2020, 08:11 PM
Add gas, time, annoyance and nearby Home Depot looks better all the time.
post #4 of 31 (permalink) Old 02-28-2020, 08:21 PM
ahhhh....
the infamous intangible cost in play...
post #5 of 31 (permalink) Old 02-28-2020, 10:05 PM Thread Starter
roofner's Avatar
First Name: Gary
Did you know to look at 20 % coupon for central machine exclusion?
post #6 of 31 (permalink) Old 02-28-2020, 10:15 PM
PhilBa's Avatar
First Name: phil
HF is totally hit or miss. Before I buy anything from them, I go to the website and read the reviews. To HF's credit they don't seem to delete any of them - so you get good, bad and really f*$Kin bad ones. This allows me to avoid the bad products. There is also a lot chatter about things to watch out for. Also, I always open the box up before I leave so I can avoid driving home with damaged or otherwise bad product.
I'm literally 10 minutes from one but having to do a round trip to get a replacement is a PITA.
I know some people won't touch HF but if I can get a usable tool for 1/4 or less the cost of the higher end ones, I'll certainly consider it. And if it's for a limited project, I see no reason to drop top $$$ on a high end one.
Visit my shop website.
PhilBa is online now
post #7 of 31 (permalink) Old 02-28-2020, 10:45 PM
For a front yard project I needed a stronger drill than my 3/8ths models. Got a half inch chuck from HF that did the trick of drilling 3/8ths holes through 2x4 so I could pound 24 inch rebar down into the ground. I will soon be drilling into concrete to set bolts to hold up scenery pieces in my long delayed theater conversion project. Need to set some TV/Film style theatrical flats to create a back stage area and want it to be well planted in the concrete. I will also try to brace it to some brackets on the back wall to make sure it stays upright. Have to also put in some side wings of some sort so people can't see back stage. Also need to hang a few extra lights because the stage is pretty wide.
I purchase four more theatrical lights a year ago and gave it to someone at the local little theater. They aren't using them, so I'll try to get them back. The price went up almost double since then and I'd really like to install all four for a total of 9 lights
Finally found my missing 8 ft ladder so i can work on the 10 ft ceiling to hang lights and some drapery. There is a black drape across the back of the stage, set about 2 ft from the back wall so actors can cross sides without being visible. Won't have a front curtain, so it will be used mainly for music performances and one-set plays or one act plays.
The seating is with free standing chairs, but they are thick padded and more comfortable than conventional theater seats.
It will be nice to get back to that project.
post #8 of 31 (permalink) Old 02-29-2020, 03:39 AM
First Name: Jessie
First off, I feel your pain. It has happened to me a few times and then I learned...
There are some things I just won't buy from HF. Mostly it's power tools I want to use more than once.
I will however buy: crappy screw drivers, drill bit sets, gloves (nitrite and work), rags, dust control (I have their 2hp for 3 years now, good buy), RO sander (another lucky buy), compressor (yet another lucky buy), sand paper, their freebies are good for gift boxes and a few other disposable items.
I did however buy the grinder you are talking about if it's the Orange one. Mine works fine for me, but I am not a professional and it doesn't get that much use.
And I agree, always check the reviews before investing in their power tools. For example: they have a Hercules table saw on sale next month $279, however lowes has a Kobalt for a few dollars more. Since I have a Kobalt Miter saw and know the quality, I'd pay a few dollars more and not get the Hercules (Hercules is also excluded from their coupons).
Also if I were a professional, I would consider all HF power tools throw aways since it would be tax deduction anyway
newbie2wood is offline
post #9 of 31 (permalink) Old 02-29-2020, 07:42 AM
Gene Howe's Avatar
First Name: Gene
HF F style clamps and their 7 mil Nitrile disposable gloves are good buys. I shy away from any of their motorized tools.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #10 of 31 (permalink) Old 02-29-2020, 08:48 AM
First Name: Art
They do have a few tools to consider. The angle grinder, which In use for metal cutting (if you don't have you get one) and the oscillating too are both well worth the money. Once I found out how useful they were I went out and bought better ones. But I still have the cheapo ones and still use them. Some of their clamps are great and their impact sockets will get the job done.
mgmine is offline
