Clone track saws and tracks - Router Forums
 11Likes
post #1 of 15 (permalink) Old 02-29-2020, 06:51 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Clone track saws and tracks
In my research if you are like me not in business you can buy a clone saw from Wen for $116 plus tax that cuts accurately . The clones can use Festool, Makita , and Powertech track $140 cut 8 ft. rip. I built a clone mft 3 table with Axminister kit using pythgruse therium for 3 4 5 right triangle. I was using eureka zone circular adapter and there track. They closed there company in December that was what lead me on this journey. I wanted a saw that had dust collection found the wen which had good results for clones lowest price. My set up for cross cutting had tape measure to cut to length. The new set up was off by 3/4 because track is 3/4 wider than eureka zone set up. Right now just add 3/4 to measurement dead on. This by far exceeds my expectation because reading dead on in comparison. I have not tested the dust collection because I have started an upgrade to my dust collection. Not up and running yet. Weather has not cooperated .
roofner is online now
post #2 of 15 (permalink) Old 02-29-2020, 09:34 PM
I'm growing fond of WEN tools. Good value, obviously standard Chinese tools relabeled, but they have exactly the casting marks of other brands. Worth checking out, and I appreciate it when people who buy them, post reviews.
dirt_dobber likes this.
post #3 of 15 (permalink) Old 03-01-2020, 01:17 PM
JFPNCM's Avatar
First Name: Jon
@roofner
Care to share a photo?
Jon
JFPNCM is online now
post #4 of 15 (permalink) Old 03-01-2020, 01:54 PM
There was a recent thread where the OP stated that Eureka Zone may be starting up again, haven't seen any follow up posts though. Did you look at the dust port the EZ offered for the saw? - it required adding a hole to the front end of the guard and drilling/tapping a couple of holes for attachment screws. I did the modification to my saw and thought that it worked pretty well - at least there was a noticeable difference in the amount of sawdust thrown out when the saw was used with and without the hose hooked up. They also sold a clear plastic shield that worked so-so, I think the idea was good, it just needed a little tweaking. There's still a fair amount of sawdust "leakage" but I think the majority of it is coming from below the sheet being cut - and I think that this is typical of most saws as I get that from my Makita. There's very little sawdust apparent when I cut on the MFT, so think, from what I read, is that the answer, for both types, is to cut with the panel on top of a sheet of foam.
DesertRatTom likes this.
tomp913 is offline
post #5 of 15 (permalink) Old 03-02-2020, 12:44 PM Thread Starter
roofner's Avatar
First Name: Gary
The track saw gets about 70 to 75 % of dust. I haven't tried duck tape over blade access hole. That where it leaks. Not sure how full the collector is either.
post #6 of 15 (permalink) Old 03-02-2020, 04:50 PM
The access hole is where my Triton track saw leaks as well. I wouldn't use duct tape, however. I think this is a job for aluminum tape holding down a small piece of thin plastic. Duct tape always leaves residue.
post #7 of 15 (permalink) Old 03-02-2020, 05:51 PM
dman2's Avatar
First Name: Dave
I just bought a Grizzly track saw and am unable to use my vac for dust collection, as their 1 1/2" exhaust port points down onto the wood, only 4" above the wood. My hose doesn't bend that much. I guess I'll need to find some kind of ell fitting or something. Not a good design... What a mess!
dman2 is offline
post #8 of 15 (permalink) Old 03-05-2020, 09:53 AM
bhethcote's Avatar
First Name: Bruce
What are general thoughts on DIY tracks built for whatever saw you own? I've seen a number of examples on YouTube look pretty sound and I'm considering that path for near future anyway.
bhethcote is offline
post #9 of 15 (permalink) Old 03-05-2020, 10:14 AM
I used my 18v DeWalt circ saw for years with an aluminum, 2 inch aluminum L bar. Even with a very good blade, I always got a little tear out, and didn't much like working from the back side. It was better than wrestling full sheets on my table saw, but the track saw is a whole different critter. Making the scoring cut and the exact edge of the track eliminated all tearout and I can work face up (less confusing).
Of course, you could do all that with a shop made saw by making a very shallow scoring cut first, and by cutting the edge off with the saw. The only caution is that having a shop made guide does not lock the saw on the cut path, a spasm or lost concentration can have you drift off the line. And the straightness of the path depends a lot on how straight the guide piece is.
The thing I don't like about the track saw I have is that it seems to have marginal power compared to an ordinary circ saw. The dust collection on a track saw, however is very nice, but to make it work you have to drag both a power cord and a dust collection tube behind you. I do all my track sawing in my garage, so I could probably hand both tubing and power overhead with a light spring to keep it up and out of the way.
I'd bet that most of the off brand track saws are made by the same no-name manufacturer.
post #10 of 15 (permalink) Old 03-05-2020, 11:24 AM Thread Starter
roofner's Avatar
First Name: Gary
The wen gives you the elbow. It has anti kick back and has the anti tipping lock for Makita track however no rival knife. I'll try and get a picture of my set up with dust collector. I'll try get metallic tape for covering the access hole. The anti tipping lock keeps the track saw perfectly flat to the track.
