Yankee screwdriver - Router Forums
 8Likes
post #1 of 14 (permalink) Old 03-02-2020, 07:20 PM Thread Starter
First Name: Wayne
Default Yankee screwdriver
Hello,
I have another question regarding The Yankee Screwdriver. I have a No. 31 that someone has jam the handle past the snap ring on the handle tube about 1". I have tried to pull the handle off but does not want to move. I do not want to damage the rest of the screwdriver trying. Push come to shove I will cut handle off and made a new one. Any ideas how I might get it off without cutting? Would anyone know what kind of wood the handles were made of? Could it be beech or apple? Any ideas will be greatly appreciated. Thank you.
Wayne
Sawdust68 is offline
post #2 of 14 (permalink) Old 03-03-2020, 08:17 AM
sreilly's Avatar
First Name: Steve
Not sure if it's rusted shut or not but I would try some solution to free the metal parts but keep the wood handle out of it if possible. When I was refinishing my #7 hand plane I used Evapo-Rust in a PVC tube to cut down on the amount needed. I cut the length a bit longer than needed, glued a PVC cap on one end and had a second cap to close the tube while the tool and solution was stood up in a bucket (in case it leaked, it didn't). Just maybe it will free up the mechanism and if not at least the rust will be gone. Worth a try......
sreilly is offline
post #3 of 14 (permalink) Old 03-03-2020, 02:44 PM Thread Starter
First Name: Wayne
The mechanical parts all work just need cleaning and fresh lub. It is the handle that I can not get off. There lager pieces missing from the other side of the handle. Evapo-rust works great. I use it to clean my flea market planes.
post #4 of 14 (permalink) Old 03-03-2020, 04:41 PM
Bob Adams's Avatar
First Name: Bob
There is a spring inside the handle, and there should be a screw on the end. Be careful, make sure to extend the driver before you try to remove the screw. In the closed position (that you photo shows) the spring is loaded and it will bite you. Don't ask, just trust me I don't know if removing the screw and spring will help with removing the handle, but since the handle is hollow it might give you a better view of what is causing the problem.
Stick486 likes this.
Bob Adams is offline
post #5 of 14 (permalink) Old 03-03-2020, 05:07 PM
The original cordless screw gun.
Herb Stoops is online now
post #6 of 14 (permalink) Old 03-03-2020, 05:36 PM
Every electrician used to have one. Best way to put on/take off cover plate screws.
DaninVan is online now
post #7 of 14 (permalink) Old 03-03-2020, 05:51 PM
And device screws...
post #8 of 14 (permalink) Old 03-03-2020, 06:59 PM
This was the common Elec screwdriver for sparkys when I was in the trades.
https://www.amazon.com/dp/B003FC75YE...osi&th=1&psc=1
the carpenters all had the Long yankees
DaninVan likes this.
post #9 of 14 (permalink) Old 03-03-2020, 07:07 PM
Originally Posted by Sawdust68 View Post
Hello,
Wayne
Maybe this will help.
https://www.instructables.com/id/Yan...r-Maintenance/
post #10 of 14 (permalink) Old 03-03-2020, 07:13 PM
Did not realise you could still buy one...
Very handy tool...
Will have to look in Bunnings...
Herb Stoops likes this.
Sydney, Australia
jw2170 is offline
