Helping a neighbor — need to fix this... - Router Forums
 27Likes
post #1 of 12 (permalink) Old 03-29-2020, 01:06 PM Thread Starter
Sominus's Avatar
First Name: Michael
Default Helping a neighbor — need to fix this...
I’m helping a neighbor fix something that his kid tried to “make better”... we all know how these things go...
Here is the problem: the screw that holds this wire to the connection was broken off at the head. That shiny/white little bit is what’s left of the screw. Somehow, that wire/connector needs to be screwed/attached permanently to its home. A quick solder was my immediate thought, but before getting out the hot tools, I thought I would throw this out there...
I have no idea how corroded the screw is inside the hole, or how tightly it is put in there (I would imagine it’s pretty tight if the head of the screw head is turned off). I just need to fix it. Thoughts?
Michael Dow
Seabrook, TX
<insert witty saying here>
Sominus is offline
post #2 of 12 (permalink) Old 03-29-2020, 01:23 PM
It might be that tight, it might have been severely weakened by corrosion. If that's on the top and not the side you might be able to eat some of the corrosion away with vinegar or Coca Cola (phosphoric acid). Then a drilled hole and an easy out might remove it. I'm partial to the left hand thread type easy outs as opposed to the straight fluted ones.
post #3 of 12 (permalink) Old 03-29-2020, 01:29 PM Thread Starter
Sominus's Avatar
First Name: Michael
That location is on a second “step”, a little ways down inside the case, but putting some vinegar shouldn’t be all that hard with a pipette.. I’ll give it a whirl...
Stick486 likes this.
Michael Dow
Seabrook, TX
Sominus is offline
post #4 of 12 (permalink) Old 03-29-2020, 02:22 PM
Or just drill it out, retap and put in a brass machine screw. You might have to go up one size (6-32 to 8-32)
TenGees, Nickp, MYB and 2 others like this.
DaninVan is offline
post #5 of 12 (permalink) Old 03-29-2020, 02:24 PM
Country: South Africa
First Name: Biagio
Michael, drill it before you apply the vinegar - if it gets loose, it may travel further in while drilling, and cause some damage underneath.
Biagio is offline
post #6 of 12 (permalink) Old 03-29-2020, 02:53 PM
use a VIX bit to drill it out...
https://www.whitesiderouterbits.com/...self-centering
chessnut2, DaninVan and Nickp like this.
post #7 of 12 (permalink) Old 03-29-2020, 03:04 PM
First Name: Jessie
agreed - drill it/tap it. I just learned how to do this recently and it works great!
newbie2wood is offline
post #8 of 12 (permalink) Old 03-29-2020, 03:19 PM
if the broken bolt moves when yur drilling it use a LH twist bit instead...
post #9 of 12 (permalink) Old 03-29-2020, 04:35 PM
kp91's Avatar
First Name: Doug
What type of object are we working on? It looks like a contactor, or part of a large appliance but I can't tell.
You might be able to find a replacement contactor for a reasonable price and save the worry of causing further damage.
If the component it is removable, I would work on the bench to prevent damage to anything else.
I would use a small LH drill if I had to save this one.
Nickp, Stick486 and sreilly like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #10 of 12 (permalink) Old 03-29-2020, 09:38 PM
Nickp's Avatar
First Name: Nick
Yup...I vote for drill 'n tap...
roxanne562001 and Stick486 like this.
Nick
Nickp is offline
