Bosch 1617EVS - Page 2 - Router Forums
 25Likes
post #11 of 26 (permalink) Old 04-03-2020, 04:00 AM
Originally Posted by Flutemaker View Post
The Bosch 1617 EVS clamp/release doesn't work smooth at all.It is coarse and hard to turn. Ive messed with it and tried to make it work.But it won't do good.I would be satisfied if I could just take the base away and just reach under the table and adjust it up as needed but the adjustment is coarse.....hard.It will work but not like my Milwaukee used to at all..The clamp /whole mechanism on it is a piece of junk!
Mike...
what is hard to turn???
the fine depth adjustment knob???
there is no clamp release to turn... it's a flip lever...
you don't open the lock you can't turn the depth knob...
you are unlocking the holding clamp before you attempt to change depth setting, ain'tja???
if you have force turned the depth knob past it's stops you have probably broken the retainer E clip...
if the motor isn't correctly installed into the base's keyways adjustment will be very difficult...
if the locking lever is over adjusted it won't allow the motor to move freely...
Start on page 11 of your owner's manual and make sure the motor is installed correctly in the base...
Make sure the coarse adjustment lever is adjusted correctly...
Center the fine adjustment screw w/o the motor in the base...
if it still turns hard w/o the motor in the base - you tore something up by force turning it...
now reinstall the motor... (page 11)
refer to page 12 for depth setting...
Name:	1617 BASE E.jpg
Danman1957 and Nickp like this.
post #12 of 26 (permalink) Old 04-03-2020, 07:16 AM
Bstrom's Avatar
First Name: Brian
Originally Posted by DaninVan View Post
OK, hold on guys; Mike specifically said 11617EVSThat's the fixed base...no mention of a plunge base. Frankly, if you have the EVSPK you have both fixed and plunge; why would you try and mount the plunge base when you have a perfectly good fixed base to mount in the table?
My bad. Yes, the fixed base is the culprit. The plunge is fine - I like it just fine. But that ‘lift’ feature on the fixed is a kludge. Compared to the Jessem or any of the other true lifts, Bosch walked away from making a proper tool here. Their base controls are even more difficult to use under a table top. Sorry to be so adamant but I fought with mine too long.
The Jessem is effortless, has a lock and is rugged. You can position the motor as you like - no freaking ‘slot’ to fight with - which also allows for dealing with longer bits very easy. Adjustment is a breeze with the smooth height crank - I use one finger to raise and lower. Combined with the Bosch RA1181 table, it will have the dual switching for DC as well. My vacuum/dust cyclone unit is part of the cart I built and it does the trick!
Common Man Woodworking
Powell, TN
Bstrom is offline
post #13 of 26 (permalink) Old 04-03-2020, 08:25 AM
Bushwhacker's Avatar
First Name: David
Mike...
Its very possible that I did the same thing with mine. It worked just great when I first installed it, but now it will not raise or lower the router at all with the top of the table allen wrench adjustment. I have to do the adjustments from under the table.
Page 11 you say.??
I will have to go back over that and see if I can fix it.
Now, where is that manual?
Stick, can you come by and take a look at it for me?
Bushwhacker is offline
post #14 of 26 (permalink) Old 04-03-2020, 08:30 AM
Page 11 you say.??
the manual is posted..
sure I can come by...
put the coffee on...
or should I bring my own...
post #15 of 26 (permalink) Old 04-03-2020, 11:18 AM
Bstrom's Avatar
First Name: Brian
I jimmied my C-clip too. That was the straw that broke this camel’s back. Hope you ind a solution to this issue, Dave.
Powell, TN
Bstrom is offline
post #16 of 26 (permalink) Old 04-03-2020, 12:07 PM
After having problems with a Rockler lift drifting with a 1617 motor, I sold the lift and instead of buying another,better lift, I just consigned the 1617s to freehand use and bought a Triton TRA001 which has a built in lift capability just by removing the plunge spring. In many cases, I've wound up using a Colt instead of the larger 1617s for light duty cuts.
I also had some problems when I first got the Bosch, but it was because I didn't read the manual so I didn't realize there was a key slot in the base. I never had a problem after that. I bought the EVSPK kit, then a second motor only for the table. Thus two machines.
DaninVan, Nickp and Stick486 like this.
DesertRatTom is online now
post #17 of 26 (permalink) Old 04-03-2020, 12:17 PM
REAL men don't read/need manuals! (or maps)
LOL!!!
Danman1957, TenGees, Nickp and 1 others like this.
DaninVan is online now
post #18 of 26 (permalink) Old 04-03-2020, 01:00 PM
First Name: thomas
But you'll have to stand outside. Remember... social distancing!
thomas1389 is offline
post #19 of 26 (permalink) Old 04-03-2020, 01:05 PM
that'll work out...
post #20 of 26 (permalink) Old 04-03-2020, 02:44 PM
Danman1957's Avatar
Here I always thought a manual was a transmission that you have to shift. LOL
DaninVan, thomas1389 and Stick486 like this.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
