Bosch 1617EVS - Page 3 - Router Forums
 25Likes
post #21 of 26 (permalink) Old 04-03-2020, 02:46 PM
It IS; why do you ask?
DaninVan is offline
post #22 of 26 (permalink) Old 04-03-2020, 04:35 PM
Nickp's Avatar
First Name: Nick
No, No, No...! It's another word for hard work...manual labor...
Nick
Nickp is offline
post #23 of 26 (permalink) Old 04-03-2020, 04:42 PM Thread Starter
Mike...
what is hard to turn???
the fine depth adjustment knob???
there is no clamp release to turn... it's a flip lever...
you don't open the lock you can't turn the depth knob...
you are unlocking the holding clamp before you attempt to change depth setting, ain'tja???
if you have force turned the depth knob past it's stops you have probably broken the retainer E clip...
if the motor isn't correctly installed into the base's keyways adjustment will be very difficult...
if the locking lever is over adjusted it won't allow the motor to move freely...
Start on page 11 of your owner's manual and make sure the motor is installed correctly in the base...
Make sure the coarse adjustment lever is adjusted correctly...
Center the fine adjustment screw w/o the motor in the base...
if it still turns hard w/o the motor in the base - you tore something up by force turning it...
now reinstall the motor... (page 11)
refer to page 12 for depth setting...
I have torn nothing up ,,,,not forced anything ! It is correctly installed !
Flutemaker is offline
post #24 of 26 (permalink) Old 04-03-2020, 04:54 PM Thread Starter
Guys have a great day.Im out of here!
post #25 of 26 (permalink) Old 04-03-2020, 05:13 PM
First Name: Peter
Hi Flutemaker
Sounds like your router is faulty and should returned for warranty repair.
pete57 is offline
post #26 of 26 (permalink) Old 04-03-2020, 06:22 PM
Bstrom's Avatar
First Name: Brian
Originally Posted by pete57 View Post
Hi Flutemaker
The base isnít faulty, just a bugger to use. Iíve been through what heís describing...
Common Man Woodworking
Powell, TN
Bstrom is offline
