Bosch 1617EVS - Router Forums
 25Likes
post #1 of 26 (permalink) Old 04-02-2020, 05:37 PM Thread Starter
Default Bosch 1617EVS
I have the Bosch 1617...While the height adjustment does work it leaves a lot to be desired.I would rather not have the setup like with the adjustment from the top.Well I can skip using that and still adjust from the bottom.It leaves a lot to be desired......Not quality at all....a piece of junk...Router itself Im sure is ok but this adjustment is ugh!
Flutemaker is offline
post #2 of 26 (permalink) Old 04-02-2020, 05:59 PM
What specifically don't you like about it (that makes it "junk"..."not quality at all")? Did you try it before you bought it?
I have one and have absolutely no problem with depth adjustments. It does take a few uses to get used to it, I will admit
MEBCWD, Danman1957, Nickp and 1 others like this.
DaninVan is offline
post #3 of 26 (permalink) Old 04-02-2020, 07:53 PM
Nickp's Avatar
First Name: Nick
Have you considered a separate lift...? The 1617 motor would come and mount in the lift...for example, the Jessem...
I don't think you'll get anything different in a different router...
Stick486 likes this.
Nick
Nickp is online now
post #4 of 26 (permalink) Old 04-02-2020, 08:32 PM
Originally Posted by Flutemaker View Post
I have the Bosch 1617...While the height adjustment does work it leaves a lot to be desired but this adjustment is ugh!
specifically why???...
post #5 of 26 (permalink) Old 04-02-2020, 09:09 PM
Bstrom's Avatar
First Name: Brian
The Bosch ‘lift’ action of the plunge base is useless under a table - believe me i tried to make mine work, but it works fine above board. I went with the Jessem Rout-R-Lift II and fitted it to the Bosch RA1181 table - required a 1/16” trimming on all edges of the phenolic base. Used Bosch leveling hardware and made holes for snugging in place.
For $189 it is the a great value and works very well. The router motor mounts and releases easily via a hex bolt. Build quality is excellent. Highly recommend.
Common Man Woodworking
Powell, TN
Bstrom is offline
post #6 of 26 (permalink) Old 04-02-2020, 11:44 PM
OK, hold on guys; Mike specifically said 11617EVSThat's the fixed base...no mention of a plunge base. Frankly, if you have the EVSPK you have both fixed and plunge; why would you try and mount the plunge base when you have a perfectly good fixed base to mount in the table?
Danman1957 likes this.
DaninVan is offline
post #7 of 26 (permalink) Old 04-02-2020, 11:54 PM
guys???
plural???
DAN!!!!
post #8 of 26 (permalink) Old 04-03-2020, 12:08 AM
That sounds like SWMBO calling; "DAN!!!"
DaninVan is offline
post #9 of 26 (permalink) Old 04-03-2020, 12:47 AM
Should I change that to !!!""DANIEL""!!!
post #10 of 26 (permalink) Old 04-03-2020, 03:00 AM Thread Starter
The Bosch 1617 evs clamp/release doesnt work smooth at all.It is coarse and hard to turn. Ive messed with it and tried to make it work.But it won't do good.I would be satisfied if I could just take the base away and just reach under the table and adjust it up as needed but the adjustment is coarse.....hard.It will work but not like my Milwaukee used to at all..The clamp /whole mechanism on it is a piece of junk!
