Green Roof planter boxes, feedback requested - Router Forums
 41Likes
post #1 of 29 (permalink) Old 05-04-2020, 02:11 PM Thread Starter
PhilBa's Avatar
First Name: phil
Default Green Roof planter boxes, feedback requested
I have a project where I need to build 50 planter boxes to go in a green roof we are building. They are of a simple design (see image below) to make it easy to bang out. The plan is to use 3/4", 5.5" width cedar. The appearance isn't important as they will be covered up by plants. We will fit landscape fabric in the bottom to prevent soil loss - the center drainage gap is 1/2" wide and the side ones are 1/4". I've got a jig worked up to make it easy to build the boxes.
I'm not 100% sure the best way to build the boxes. This is where I could use some advice. Are staples the right fastener - will work better than nails? I know that the acid in cedar will react with iron to make dark stains but they won't be visible so that's ok. I think galvanized is the way to go though maybe copper will last longer? Not 100% sure. Also, are 18 gauge staples reasonable? I think any thinner won't be strong enough. Thinking 1 1/2" length.
Also, looking at pneumatic staple guns. Any suggestions as to brands and or models? Probably don't need a beast to drive 1 1/2" staples into cedar.
Visit my shop website.
PhilBa is offline
post #2 of 29 (permalink) Old 05-04-2020, 02:25 PM
Nickp's Avatar
First Name: Nick
Nice project, Phil...
I would think the box will be big enough so that the dirt will want to push the sides out a bit. And if you need to carry it at all with dirt in it, it will no doubt rack on you a bit.
With that, my suggestion would be coated deck screws...You're gonna need 800 of them considering two for each board end...
15 or 16 gage nailer would probably do the trick...thinking 5 per board end...
Bostitch makes a good gun in that size...
Nick
Nickp is online now
post #3 of 29 (permalink) Old 05-04-2020, 02:25 PM
Bstrom's Avatar
First Name: Brian
Under such conditions, how long will Cedar last in the open? Especially the bottom?
Regarding the build, would it be a lot trouble to cut a locking miter for the corners to get the most strength with no extra effort? Uses just one bit and is just as easy as a butt joint to assemble...I would think the same staple size as a hardwood floor nailer uses would pretty beefy.
This is an interesting project logistically...
PhilBa and Herb Stoops like this.
Common Man Woodworking
Powell, TN
Bstrom is offline
post #4 of 29 (permalink) Old 05-04-2020, 02:26 PM
A HF staple gun ought to work fine for a one time projrct like this,with 1 1/", or 2" staples.
HErb
Herb Stoops is online now
post #5 of 29 (permalink) Old 05-04-2020, 03:11 PM Thread Starter
PhilBa's Avatar
First Name: phil
Wow, that was fast!
Nick, Yes, I expect a bit of movement. They will be placed side by side on the roof. The plan is to plant the starts in them and carry them up to the roof area - 2 flights of stairs. So soil and plants but not watered. Probably 20 lbs range. I'm going to think about maybe shortening the boxes a bit to minimize bowing. Especially if I can't find cost-effective 3/4" cedar. I dunno, screws add a huge amount of labor - I'd need to drill pilots and would worry about splitting the cedar. Definitely a better way to go in general, though. If there were planters that sit on a deck and get admired for the design and construct, there would be no question of using better joinery.
Brian, The boxes will sit on a drainage layer - pumice covered with landscape fabric (well, something a bit upmarket from that). They won't be standing in water though still fairly wet. We are putting low water plants in so we will let the boxes dry out a bit. Still, I expect at least a 5 year lifespan or so. The commercial units are plastic but they only warrant them for 3 years. Lock miters - for anything indoor, I'm totally there. The goal is to get this done with some low skilled help (aka family) in a reasonably short amount of time. Banging out the rough-cuts first - 300+ cuts. Pretty easy with a stop on my SCMS. Then 8 miter cuts for each box - 200. The butt joint starts to look like a good idea.
Herb. Yeah, looked at the HF 29.95 stapler. It get's ok reviews on the HF site so probably worth trying. if it doesn't work well, I can always get a better one and I'm not out a lot.
Nickp likes this.
PhilBa is offline
post #6 of 29 (permalink) Old 05-04-2020, 03:24 PM
Narrow crown SS staples will work fine provide you change the corner joints from butt joints to rebated rabbets for the reasons Nick gave...
you will have to staple into both the long and short sides...
deck screws will split the wood because you are at the ends of the boards and the shape of the head acts as a wedge...
grove the bottoms of the sides to accept the bottom slats... do this joint as a rebate also...
when you assemble let the bottom reveal show..
when you do your glue ups treat the wood as an oily tropical wood...
size the end grain..
I strongly suggest you use Weldbond instead of TB... Weldbond is waterproof...
Use synthetic, non-water-based glues.
Since water is repelled by the wood’s oils, using water-based glues like Titebond® can pose problems—though Titebond® II or III are usually better at gluing oily woods than Titebond® Original. Instead, use glues that aren’t water based, and/or glues that can bond a wider variety of materials like plastics and other non-porous surfaces (since that’s practically what we’re doing with these exotic woods anyways). Weldbond will do a way better job since it will meet the mentioned criteria...
Wipe the wood surface with a solvent prior to gluing.
Since the primary problem that tropical woods present in gluing is their oiliness, (with density probably being the second biggest problem), any of these natural oils and resins that you can remove from the wood surface will help the glue adhere that much better.
While it’s not a cure-all, wiping the wood with a solvent first goes a long way. But you have to be sure of two things: first, you should try to glue the pieces of wood to be joined as soon as possible after the solvent has evaporated from the wood surface. This is because the wood’s oils will tend to migrate back to the surface of the wood where you removed some of the oils. Secondly, you have to be sure that the solvent you’re using is actually dissolving and removing the wood’s oils. A good way to gauge this is by checking the towel that you’re using to wipe the solvent to see if it’s changed to the wood’s color.
Note:
If you’re initially testing a solvent, make sure that the wood is clear of any small particles of sawdust that might make it appear as though the towel is being discolored. Try a cloth with water first as a baseline: it should basically stay white since the water does not dissolve the wood’s heartwood extractives. Some common solvents that you can try are: acetone, denatured alcohol, lacquer thinner, mineral spirits, and naphtha.
Name:	rebate rabbets.jpg
JFPNCM and Nickp like this.
post #7 of 29 (permalink) Old 05-04-2020, 03:48 PM
Bstrom's Avatar
First Name: Brian
Originally Posted by PhilBa View Post
Wow, that was fast!
Would a simple stretcher 1X1 across the top edge after you have done the planting help keep the side panels under control?
I sincerely wish you well with the carrying chore - you have your work cut out for you!
Powell, TN
Bstrom is offline
post #8 of 29 (permalink) Old 05-04-2020, 03:49 PM
JOAT's Avatar
First Name: Theo
HErb
Likely would. However, I have not been able to log onto the HF site for at least a couple of weeks. I would like to order 2 or 3 things from them, I had assumed they would at least have the mail order side still going, but possibly not.
Herb Stoops likes this.
JOAT is offline
post #9 of 29 (permalink) Old 05-04-2020, 04:17 PM
Look in the wooden fence section at HD or Lowes for the cedar boards, they are usually good quality, the last time I did a project I used them for some planters,the boards are planed one side to 5/8" thick, 6' an 8' long. They might have some full roughsawn 2 sides for 3/4" tho. Don't use treated, might effect plant growth.
Nickp and Stick486 like this.
post #10 of 29 (permalink) Old 05-04-2020, 04:26 PM
The deck screws would hold it together better but you'd need to predrill pilot holes and be a bit careful about over torquing the heads. It's such a soft wood that it will tolerate a bit of crushing without splitting usually but going into the sides without the pilot will split some of the boards. I've used untreated cedar for fence pots and fence rails and your lifespan is a max of about 8 years. Oiling it would help. \
I don't know if I'd bother with any glue. I've tried all kinds, including resourcinol and PL400 and NOTHING holds for long. Some of the stainless fasteners I've used were very slick and pulled apart easily. Galvanized tends to grip better and will probably last about as long as the boxes will. The strongest corners using just small air driven fasteners would be cross nailed miters.
DaninVan, Nickp and Stick486 like this.
