He BROKETED It! - Router Forums
 95Likes
post #1 of 47 (permalink) Old 05-05-2020, 08:16 AM Thread Starter
OutoftheWoodwork's Avatar
First Name: Barb
Unhappy He BROKETED It!
He did! He did! Ken broketed my drill press! (That's #2 drill press he's done now....)
The center doo dippy dobby is out and it won't go back in (The chuck and the spindle it's attached to.) Ken kinda goofed and tried to use one of those circle saw cutters, and part way into the cut, the whole dam chuck popped/dropped out. Now, I don't have the book on this, and I don't have the tool that you're supposed to use to remove this chuck, and it' just popped out. Now he can't get it back in, and I don't know where to get parts. I've been looking on line this morning, and using model number will only bring up garage journal forum.
Here's the picture of the label on the front; any ideas, guys? I need my drill press back to finish projects (and start a couple, too).
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
post #2 of 47 (permalink) Old 05-05-2020, 08:25 AM
difalkner's Avatar
First Name: David
Do you have a photo of the chuck, Barb? Is it a Morse taper? If so, just make sure everything is clean and tap it back into place. Run the chuck jaws up to where they're inside the body of the chuck and use a block of wood and mallet to tap it back in.
David
kp91, jw2170, neville9999 and 5 others like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 47 (permalink) Old 05-05-2020, 09:10 AM
RainMan 2.0's Avatar
I believe my drill presses chuck is pressure fit Barb . The part that went up was kind of a cone if I remember correctly
roxanne562001 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 47 (permalink) Old 05-05-2020, 09:14 AM
difalkner's Avatar
First Name: David
That's a Morse taper, Rick.
David
Herb Stoops likes this.
David
Romans 3:23
post #5 of 47 (permalink) Old 05-05-2020, 09:40 AM
roxanne562001's Avatar
First Name: Roxanne
roxanne562001 is offline
post #6 of 47 (permalink) Old 05-05-2020, 09:50 AM
CharleyL's Avatar
First Name: Charley
The tapered parts have to be absolutely clean, both mating parts. Then you just press them together hard. I have just raised the table high, placed a piece of 2 X 4 on it and, with the chuck opened wide so you are pressing against the outer handle part of the chuck, just lower the spindle and press it down hard. After, move the table out of the way and swing a dead blow hammer upwards, hitting the chuck in an upward direction.
That should seat it, until the next time.
Morse tapers are great, if they are clean and seated tight. When they aren't clean they will not stay together.
If you should ever need to separate the taper to replace the chuck, or for some other reason, there is a slot just above the taper in the spindle. A tapered metal wedge driven into the slot will pop the taper apart. Be sure to have someone holding the chuck so it doesn't fall.
Charley
Central North Carolina
CharleyL is offline
post #7 of 47 (permalink) Old 05-05-2020, 11:04 AM
The info is on the metal label; MT #2 (Morse Taper)
DaninVan is offline
post #8 of 47 (permalink) Old 05-05-2020, 11:44 AM
CharleyL's Avatar
First Name: Charley
#2 taper is quite common for drill presses, and some lathes.
I bought a Delta bench top drill press about 20 years ago and the taper fell apart on me several times, no matter how clean I got the tapered parts. Then I bought one of these.
After success, I loaned it to my #2 son and haven't seen it since. You don't need one, if you can get the inside taper clean and smooth enough. The outside taper on the drill chuck cleans easily. Even the slightest spec or burr will keep them from staying together. Use a mirror and light, if necessary, to inspect the inside taper. With both surfaces clean, you shouldn't need the following. You will need the cleaner to fit a #2 taper -
The inside taper cleaner -
https://www.woodturnerscatalog.com/p...-Taper-Cleaner
The removal tool for Morse tapers is -
https://www.carbideanddiamondtooling...-105-ID-16755-
Don't necessarily buy from these sources. These links are just intended to show what you need. Shop around for the best deal.
Charley
CharleyL is offline
post #9 of 47 (permalink) Old 05-05-2020, 03:26 PM Thread Starter
First Name: Barb
David
David, this is what I have. Ken told me (after I already posted here) that he got the mechanism to go back in, but he's not sure if he got it in all the way. I can't tell, because none of my pictures of my drill press are close enough to tell where it sat before he broketed it.
Wish I could find the book to this thing somewhere.
roxanne562001 and jj777746 like this.
Barb
Mark Twain
Henry A. Kissinger
post #10 of 47 (permalink) Old 05-05-2020, 04:10 PM
difalkner's Avatar
First Name: David
So are you saying that's as far as the chuck will go in the quill or that the quill has become disengaged with the gear and that's as high as it will go? In other words, are you unable to get the bottom red line up to where the top red line is? The chuck looks like it's fully seated, btw.
David
jj777746 likes this.
David
Romans 3:23
