Clutch on thicknesser - Page 2 - Router Forums
 15Likes
post #11 of 12 (permalink) Old 05-23-2020, 09:20 AM Thread Starter
Wildwood's Avatar
Country: South Africa
First Name: Rob
@Nickp
Are you using the Wondaflex as the clutch material or did you use it to bond material with it...?
Nick, I'm using the Wondafix as the actual clutch material - it mentions friction drives as one of its uses, and my tests gave excellent adhesion results on metal. and the cured surface has a bit of 'give' in it, so I'm hopeful for long term results.
I will be doing a lot of planing in a couple of weeks time, and that will be the acid test. I will certainly report back, (for better or for worse!)
Stick486 likes this.
Wildwood is offline
post #12 of 12 (permalink) Old 05-23-2020, 09:29 AM
Nickp's Avatar
First Name: Nick
Originally Posted by Wildwood View Post
@Nickp
It seems that as an adhesive it would be used to bond the friction material for any drives that engage and disengage, like your recent leather material. Your drive is likely to require some slippage before completely engaging and I wonder if Wondafix will allow it to do that.
I surely hope it works but I would take a look at the engaging surface every few times you use it.
Best luck...let us know how it goes...
Wildwood likes this.
Nick
Nickp is offline
