How would you cut this quarter circle? - Router Forums
 7Likes
  • 2 Post By jemangin
  • 2 Post By difalkner
  • 1 Post By gdonham1
post #1 of 9 (permalink) Old 05-21-2020, 10:29 AM Thread Starter
First Name: Jamie
Default How would you cut this quarter circle?
I am making a fan type knife block. It is made from seven wedges with spacers for the knives. My plan was to glue it up then cut a circle/curve on both ends to even everything up. It is 3" wide by 12" long by 12" tall.
Band saw circle jig? Make a circle pattern then pattern bit on router table? I think I will have to cut the curve before putting the spacers in to avoid blowing out every edge.
Advise needed.
Jamie.
Nickp and sreilly like this.
jemangin is offline
post #2 of 9 (permalink) Old 05-21-2020, 11:24 AM
difalkner's Avatar
First Name: David
I would still use the bandsaw but would place sacrificial wedges between each section to prevent blowout. Then just remove the wedges and you should have a clean edge. Use a finer tooth blade, though.
David
roxanne562001 and sreilly like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 9 (permalink) Old 05-21-2020, 02:44 PM
The same style jig for cutting curves on a bandage works on sanding machines too.
post #4 of 9 (permalink) Old 05-22-2020, 02:19 PM
Bstrom's Avatar
First Name: Brian
How did you cut those wedges so cleanly?
Common Man Woodworking
Powell, TN
Bstrom is offline
post #5 of 9 (permalink) Old 05-22-2020, 09:02 PM Thread Starter
First Name: Jamie
I used a table saw angle jig on the bandsaw. Then jointed the cut surface before cutting the next wedge. Did a real clean job of it. Dialed the angle in using a scrap first.
Thanks for the help. Knew you guys would have the answer.
kp91 and Herb Stoops like this.
jemangin is offline
post #6 of 9 (permalink) Old 05-23-2020, 12:47 AM
gdonham1's Avatar
First Name: Guy
I dont like those type of jigs. The piece is loose and can get out of control. I prefer a home made version similar to the commercial jigs that lay flat with clamps to hold your work. Microjig and Rockler have some examples.
Stick486 likes this.
gdonham1 is offline
post #7 of 9 (permalink) Old 05-23-2020, 02:04 AM
swap the sticky tape for non-skip...
post #8 of 9 (permalink) Old 05-23-2020, 02:08 AM
same only different...
post #9 of 9 (permalink) Old 05-23-2020, 06:32 AM
ger21's Avatar
First Name: Gerry
I'd use a bandsaw. More sanding required, but less tearout.
Ger
www.cncwoodworker.com
ger21 is online now
