Skew Block Planes - Router Forums
 2Likes
  • 1 Post By mimac
  • 1 Post By TWheels
post #1 of 5 (permalink) Old 08-01-2020, 12:21 PM Thread Starter
First Name: Don
Send a message via AIM to Jimmy Dee Send a message via Yahoo to Jimmy Dee
Default Skew Block Planes
Need recommendation on which to purchase:
1) Veritas DX60 Block Plane, https://www.leevalley.com/en-ca/search?query=05P76.71, PM-V11 Steel Blade, $229.00, OR
2) https://www.lie-nielsen.com/products...ck-plane-right (Based on Stanley 140) $225.00
The L-N is weaker in design, based on the fact that one side is completely open when the "Removeable Side Plate" is removed for use. The Veritas design has the frame running full length on both sides.
Both have a removeable wood fence on the side, which can be switched out with a much longer, full length of the plane fence, for better stability.
Both are about the same size. Both have similar blade adjustments, except the Veritas has left and right "grub" screws for lateral movement and stability. The Veritas is made of ductile iron and the L-N made of bronze.
Don
Jimmy Dee is offline
post #2 of 5 (permalink) Old 08-01-2020, 12:35 PM
Don; Never used one but can I assume the open side is to allow you to work up flush to a shoulder (vertical surface relative to the face the plane is sitting on)?
If so it would seem like a reasonable design compromise considering the benefit of that. Unless the plane is dropped onto concrete, does it really detract from the body's strength?
DaninVan is offline
post #3 of 5 (permalink) Old 08-01-2020, 01:36 PM Thread Starter
First Name: Don
Dan,
The blade is able to adjust outward on the Veritas to the outer edge of the plane body to enable it to cut completely vertical shoulders as well. Would be nice if someone could comment on these two planes that has actually seen or used both.
Don
post #4 of 5 (permalink) Old 08-01-2020, 08:31 PM
mimac's Avatar
First Name: Brian
I have the Veritas and am really happy with it. Probably the most used af all my hand planes.
Jimmy Dee likes this.
mimac is offline
post #5 of 5 (permalink) Old 08-03-2020, 09:02 PM
TWheels's Avatar
I have the Veritas skew block planes with PM-V11 irons. They are absolutely first rate.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
