Material for table saw cross cut sled - Page 3 - Router Forums
 73Likes
post #21 of 24 (permalink) Old 08-19-2020, 08:16 PM
First Name: ben
Originally Posted by JOAT View Post
I always use 1/2" plywood for mine, no screws or nails, all glue fastening.
When I am designing things, I tend to be thinking about re-usability of bits and pieces for some future project. All glue precludes that. However, I am rethinking my design philosophy because the most critical thing about a sled is that the runners remain absolutely fixed in place after the saw kerf is made in the sled. This insures that the saw kerf will remain parellel to the miter slot on the table saw.
Have you used any plastic runners and if so what kind of glue do you recommend?
bfblack is offline
post #22 of 24 (permalink) Old 08-20-2020, 04:17 PM
First Name: ben
Originally Posted by opticsguy View Post
Preparing to design and make a crosscut sled for my table saw.
Since I want perfectly flat material any problems in using MDF or Particle board for the base? Yes I understand that moisture can alter the material but my shop is dry and would probably seal it.
Thankyou.
This thread prompted me to dust off some cross cut sled notes that I have accumulated over the last few years.
File Type: pdf Cross Cut Sled Notes for the Newbie.pdf (139.9 KB, 25 views)
Nickp likes this.
bfblack is offline
post #23 of 24 (permalink) Old 08-20-2020, 05:00 PM
Nickp's Avatar
First Name: Nick
Originally Posted by TwoSkies57 View Post
About 10 years or so ago, I built what I considered a premium CC sled. When I finished, I had what I sought to build. However, 10 years down the road you tend to view things a little differently. The sled I biuld, to this day is rock solid, performs beautifully and does everything I could ask of it. Not bad ya might say....but, sometimes more is not necessarily better. The more bells and whistles you add, the more weight you add. Bigger is heavier (typically, especially if your using standard materials) Esthetics do not necessarily add to functionality!!!!! I tend to like to build jigs that look cool, but that doesn't mean that work any better than one built to bare bones standards. Consider carefully application and practical usage.
IMHO the foundation for a really good sled has got to be Baltic Birch ply. Second choice would be a really good sheet of oak or maple ply. Just not a big fan of MDF for this kind of application. And certainly not particle board. Longevity is always an issue with shop built jigs and i just don't see either material holding up after a few years of use. 3/4" plys work great, but there is always the weight issue. If its just a small sled, then it probably won't make that much of a difference, A medium to large sled, it'll start adding up quickly. Most of the assembly can be handled with good screws. 1/2" ply works great, ya just gotta be careful when installing T-tracks etc.... 1/8th inch isn't much to hold a screw. I prefer to go with an epoxy on 3 sides to hold tracks in place. Pretty much eliminates any flex. Dado fences into place, don't use butt joinery. .....The very best advice I could give would be to just build one. See what you like, don't like, what works for ya, what don't and consider how to improve upon the design... then build the next one based on what you've learned.
Here's a link to one of my sled builds..
https://www.routerforums.com/twoskie...scut-sled.html
Holy [email protected], Bill...that is one helluva sled...good enough for Rudolph to use at Christmas...
Thanks for the re-post...
TwoSkies57 and Herb Stoops like this.
Nick
Nickp is offline
post #24 of 24 (permalink) Old 08-21-2020, 07:26 AM
TwoSkies57's Avatar
Thanks Nick.... appreciate that...
Yep, she sure is purity *L*..but more importantly, completely functional.
I think that Rudolph would love using it, but may need a couple elves to help get the damn thing up on the table
TenGees and Nickp like this.
Skipper the Penguin
TwoSkies57 is offline
