Template to Cut Gear Teeth on Plywood? - Router Forums
 14Likes
post #1 of 15 (permalink) Old 09-26-2020, 04:17 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Template to Cut Gear Teeth on Plywood?
I’m making a wooden clock and of course I will have tons of gear teeth to cut which I never done before. The gears size which all will be made from 1/4” or 1/2” plywood vary from 8” to 1” OD.
I will have a pattern for each gear which I will glue to my plywood and have no problem rough cutting the teeth with my bandsaw / router / sander but I can see a problem when the time comes to do the trimming of each tooth to achieve the right curve and make them all identical (some teeth are straight and some have a slight curve).
Has anyone developed some kind of a template for this kind of work or can suggest a way to achieve good results?
Nicolas
kolias is offline
post #2 of 15 (permalink) Old 09-26-2020, 05:00 AM
scroll saw for machine...
rough cut and use an Olson plain end scroll saw file #42100 for finessing and clean up...
fret saw for by hand...
make the teeth as inserts...
do you have a lathe???
find - wood gear cutting by Ron Walters
YT is ate up w/ videos on this...
Stick486 is offline
post #3 of 15 (permalink) Old 09-26-2020, 06:15 AM Thread Starter
kolias's Avatar
First Name: Nicolas
As mentioned, I have no problem cutting the teeth.
I’m looking for a way to have the teeth identical after the rough cut like you would have done if you were using a CNC. I have an idea of using a template and use my router to follow the template to trim each tooth so all teeth will be identical. But this is just an idea right now and working to see how I can implement this idea.
Nicolas
kolias is offline
post #4 of 15 (permalink) Old 09-26-2020, 06:17 AM
can you find steel gears to use as templates???
Stick486 is offline
post #5 of 15 (permalink) Old 09-26-2020, 06:21 AM
these links might foster ideas...
an indexer will be the most valuable tool...
https://www.star-su.com/cutting-tool...cutting-tools/
https://www.cnclathing.com/guide/gea...ing-cnclathing
https://capitalgeartools.com/milling-cutters/
Stick486 is offline
post #6 of 15 (permalink) Old 09-26-2020, 09:26 AM
Forum Moderator
difalkner's Avatar
First Name: David
There is an add-on to Fusion 360 that will generate gears for you. Works pretty good.
Here are some of the ones I've cut using F360 for the CAD/CAM and cut on my CNC -
David
old55, RainMan 2.0 and Herb Stoops like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 15 (permalink) Old 09-26-2020, 10:02 AM
JOAT's Avatar
First Name: Theo
That's how I do my stuff. Use 1/2" plywood, spend time, make one of whatever perfect. Then glue that one onto a piece of 1/2" plywood, rout it. That give me a 1" thick master - easier to hold on to. I drill pilot holes in the master, use those and tack the master to the rough cut piece, rout, and have a finished piece. Repeat until you have all of those particular pieces you want. Repeat for each different size or pattern. Works for me.
JOAT is online now
post #8 of 15 (permalink) Old 09-26-2020, 05:47 PM
TWheels's Avatar
https://www.woodgears.ca/gear_cutting/template.html
The number of teeth is variable and one can even create templates for rack and pinion systems.
DaninVan, TenGees and peterbata like this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #9 of 15 (permalink) Old 09-26-2020, 07:54 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Thank you all for the ideas, now it’s time for me to use what I learned and along with my ideas try to find out the best way to cut my first gear. Obviously I will have to experiment on some scraps first and I will post the results
TWheels, TenGees and Roy Drake like this.
Nicolas
kolias is offline
post #10 of 15 (permalink) Old 09-26-2020, 08:14 PM
Nickp's Avatar
First Name: Nick
Here's a technique for using a table saw...just another option...but it seems to add the rounded edge for matching gear teeth...
Good luck
Nick
Nickp is offline
