Bosch 4100: Insert plate - Router Forums
 7Likes
post #1 of 16 (permalink) Old 09-28-2020, 08:22 PM Thread Starter
Default Bosch 4100: Insert plate
My retired machinist neighbor picked up a used Bosch 4100 TS last Winter, He did a major cleanup and adjustment on it and it's running perfectly now.
I gave him my old 8" dado set, so he was committed to making some DIY table inserts, before he could use the dado set.
OK; question.
on one the side of the table opening (left below) there is a raised ledge, part of the table casting and nothing to do with the insert leveling pads.
Have any of you 4100 owners removed that ledge to simplify making DIY plywood insert plates?
(See pic below)
He can work around it but it'd sure be simpler if it wasn't there...i did mention that he's a machinist.
DaninVan is offline
post #2 of 16 (permalink) Old 09-28-2020, 08:56 PM
it's there as support for thin metal or plastic inserts...
work around it.. DO NOT remove it...
Stick486 is offline
post #3 of 16 (permalink) Old 09-28-2020, 11:36 PM Thread Starter
Poor engineering then; it's at a higher level than the leveling pads. He can certainly work around it by routing that section deeper...just a p.i.t.a.
*bonus; he had a great time today dadoing, after making the plywood insert. First time dadoer...
TenGees likes this.
DaninVan is offline
post #4 of 16 (permalink) Old 09-28-2020, 11:48 PM
nope...
cake and pie..
nope...
excellent...
the thinner ZC's are thicker at the pads to allow for more threads...
Stick486 is offline
post #5 of 16 (permalink) Old 09-28-2020, 11:54 PM Thread Starter
Doesn't explain why they raised that one section, unless it had something to do with the design of the casting.
DaninVan is offline
post #6 of 16 (permalink) Old 09-29-2020, 06:27 AM
Nickp's Avatar
First Name: Nick
I'm guessing you and your friend did find this... at $5 it seems to be a good deal...it clips in like the original, nice and solid...
https://www.homedepot.com/p/Bosch-41...1005/203688712
...just a thought...
TenGees and Stick486 like this.
Nick
Nickp is offline
post #7 of 16 (permalink) Old 09-29-2020, 06:47 AM
it's also a key way...
Stick486 is offline
post #8 of 16 (permalink) Old 09-29-2020, 06:48 AM
that'll give you a dado insert also...
Stick486 is offline
post #9 of 16 (permalink) Old 09-29-2020, 10:36 AM Thread Starter
Nah...he needs the DIY insert experience. LOL
But, good to know, even though there's no HD up here.
I'll send him that link.
DaninVan is offline
post #10 of 16 (permalink) Old 09-29-2020, 11:01 AM Thread Starter
All the regulars are bailing; me too.
Ciao, everyone.
DaninVan is offline
