Gluing A Rabbett - Router Forums
post #1 of 20 (permalink) Old 08-17-2005, 04:02 PM Thread Starter
Default Gluing A Rabbett
I am in the process of making a shotglass display case/box for my wife and have used a rabbett on the sides to hold it together. now the question i have is what is the best way to glue the joints? should i use glue or glue and nails? what is the best way? i should use something more than glue right?
if i do use nails, what type??? my sides are 2" wide so theres no a whole lot of room for nails.
any suggestions?
reds_21
shawn
reds_21 is offline
post #2 of 20 (permalink) Old 08-17-2005, 05:33 PM
Visteonguy's Avatar
First Name: Terry
Hi Shawn.
I would vote for the glue AND nails.... Do you have a pnumatic nail gun, like a brad nailer, Shawn ? They drive brads in there and leave a very small hole that is easy to hide. The brad actually just holds it in place while the glue sets up and I think that is where ya really get your strenght...
If you got enough room and have a biscut joiner,,, maybe you could sneak a biscut in there to increase the strenght of the joint, to tackle it from another point of view.
One nice thing about wood working,,,, there are lots of ways to get you where you want to go.
Another way would have been to make box joints at the ends of the joining peices and glue them,,, they are easy with the jig that Bob demo's on his show and work great and also look like you put a lot of craftsmanship into the peice.
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline
post #3 of 20 (permalink) Old 08-17-2005, 06:32 PM
If feasible, use glue and staples. Staples are a better fastener than nails
for the application you cited.
Routerbit is offline
post #4 of 20 (permalink) Old 08-17-2005, 07:43 PM Thread Starter
Terry
I do have an air gun. it holds 3/8"-2" nails. would this be to big or should i go smaller?
shawn
reds_21 is offline
post #5 of 20 (permalink) Old 08-17-2005, 07:45 PM Thread Starter
routerbit........
i do have a heavy duty stapler but i think it's the wrong kind of stapler your referring to. it is a stapler that i used to hang xmas lights up on the side of the house or if i want to fasten cable tight to the wall. can i use this or what else did you have in mind?
shawn
reds_21 is offline
post #6 of 20 (permalink) Old 08-17-2005, 08:11 PM
GoonMan's Avatar
First Name: Randy
Hello reds_21,
I use 16 and 18 gauge finishing nailers or brad nailsers as some call them and have a 1/4" Crown Molding Stapler that I use on some shelfs. Before I bought my Crown Stapler I used the 18 gauge nailer and sometimes the 16 gauge nailer and glue on most of my shelf work. I picked up the stapler at Harbor Freight for $19.95 on sale. I have started using the crown stapler more and more now that I have gotten used to it.
GoonMan is offline
post #7 of 20 (permalink) Old 08-17-2005, 11:38 PM
Visteonguy's Avatar
First Name: Terry
Well, Shawn, it depends on the size of the hole it leaves behind,,, and that would depend on the gauge size of the nails,,,, Staplers are nice too, they do have better holding power. but leave a noticable hole, because they are,,,, Staples,,,,, if you are putting them some place where they will not be noticed, then they are fine ... like holding on the back or something like that,,, If I was going to have to fasten the side or front,,, I would stick with the air brad or finnish nailer,, becaues you can just put a dab of wood puddy in the hole if its noticable,,, hahaha I think I have bought EVERY nailer that Harbor Freight sells,,, and they work fine for me,,, especially at the prices they ask for them,,,
I see that Randy is a desciple of HF,,,, great !
Shawn.. you did not say what gauge your nailer is,,, could be maybe about 16 gauge,,, shoot it into a peice of scrap wood and see what the hole looks like,, if you can live with it and have nails that are a good size to use, just use it and then fill the holes to hide them. I do not think the longest ones are a good choice in this case,,, too much of a chance to blow out the side and ruin your peice. You are really depending on the glue to do most of the holding together in the end, so dont go over board on the nails and creat more work for yourself to hide them.
I made a golf ball display case not long ago and it is probably a lot like what you are making,,, not a lot of nails in it... mostly glue.
Terry
post #8 of 20 (permalink) Old 08-18-2005, 07:53 AM Thread Starter
Terry
i actually bought my nail gun through grizzly, there web address is: www.grizzly.com. i bought model number H5527. it is an 18gauge 3/8"-2" nail gun. is this a bit much for what im doing? just because my gun holds 3/8"-2" nails, can i put smaler nails in it or is that the only size it can hold?
well my box isn't as decked out as yours, more of a box than decorative!!!!
as for harbor freight, im not to fond of them, we have one down the road but steer away from that as much as possible. haven't heard a lot of positive feedback. but to each his own right? whatever floats the boat!!!!
once i get some pictures of the box i'll post them but it won't be for awhile. trying to get some of the other issues out of the way that im having with my router table.
thanks
shawn
reds_21 is offline
post #9 of 20 (permalink) Old 08-18-2005, 09:12 AM
First Name: jerry
The gun will accept brads as small (in lenght) as 3/8" or as long as 2" ,or any available size in between. The glue you use is stronger than the wood itself, the brads just secure the joint while the glue dries. If you have enough clamps the brads (mechanical fasteners) aren't really necessary.
regards
jerry
jerrymayfield is offline
post #10 of 20 (permalink) Old 08-18-2005, 09:44 AM
reible's Avatar
regards
jerry
Jerry is right about the glue. Way back in highschool shop one of the tests we had was to glue up a bunch of joints and to pass the wood had to break not the glue.... it was a trick test as everyones failed with the wood breaking.
Ed
reible is offline
Rail Stile / Ply Panel gluing / finishing steps? Nickbee The Finishing Touch 10 12-12-2007 10:22 AM
Tips for gluing panels together? Nickbee Tools and Woodworking 3 11-29-2007 12:39 PM
Gluing Joints nzgeordie The Finishing Touch 3 04-12-2007 09:37 AM
Keeping something square when gluing? ygdrasil54 Starting Off 5 10-30-2006 04:59 PM
