router horsepower - Router Forums
post #1 of 12 (permalink) Old 06-08-2009, 10:31 AM Thread Starter
DJeansonne's Avatar
First Name: Don
Default router horsepower
I am looking to purchase a second router and not sure about the HP. When is the mid-sized ~2 - 2 1/4hp adequate and when do you need the big 3 hp routers?
It seems that the 2hp routers fit 95%+ of projects and you can still do raised panels at reduced speed and a slower feed rate.
What am I missing if anything?
Don Jeansonne
Cajun Woodworker
DJeansonne is offline
post #2 of 12 (permalink) Old 06-08-2009, 01:48 PM
dutchman 46's Avatar
First Name: Howard
Hello Don; I believe that you can do everything, except the biggest of the router bits, with a 2 1/2 hp. If you are doing the doors, and using the big bits that are 3 in. wide for the recess, then i would go 3, 31/2 . Now, the same is true if most of what you do is the smaller cuts , Then you could go with the smaller Colt size routers. You can go bigger ,or smaller, on occasion, but that is what i feel is how to find the size of router that will fit me best
John 3:16
dutchman 46 is offline
post #3 of 12 (permalink) Old 06-08-2009, 02:40 PM
HI Don
" What am I missing if anything?" = not a thing you got it nailed...
Many ways to do panels,the big panel bits are not needed most of the time..about the only time you need them is where you want to make some archer panels/frames then you can make more than one pass..and it's safer most of the time...they do make over size bearing for the big bits just for that for that job. about 4.oo dollars each.
post #4 of 12 (permalink) Old 06-08-2009, 03:36 PM
Noob's Avatar
First Name: Paulo
Out of curiosity, would vertical raised panel bits require less horsepower than standard horizontal panel bits?
vertical panel bits LINK
Noob is offline
post #5 of 12 (permalink) Old 06-08-2009, 05:01 PM
HI Paulo
They work very well and take less HP to get the job done..here's snapshots after the job was done..
post #6 of 12 (permalink) Old 06-08-2009, 05:11 PM
TWheels's Avatar
What size router do you have now? My only router is 3 1/4 hp (2.4 kW) a nd it does everything I need with no strain. If you do not have a 3 1/4 hp router that should be your next buy. The price difference between the 2 hp and the 3 1/4 hp models is not that great.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 12 (permalink) Old 06-09-2009, 09:47 AM Thread Starter
DJeansonne's Avatar
First Name: Don
Default existing router
I have a PC690 with 1 3/4 hp which does most everything well going slow and smaller cuts. There seems to be a $100 to $150 cost delta for the #hp routers I looked at not counting on a sale or re-conditioned machine. I understand that I could get a PC 2 1/4hp motor that would fit in my existing PC690 bases which maybe an advantage.
Don Jeansonne
Cajun Woodworker
post #8 of 12 (permalink) Old 06-09-2009, 10:24 AM
Noob's Avatar
First Name: Paulo
HI Paulo
Those bits look like they did a clean job. Obviously it may depend on what one plans to build, but it looks like a 3 1/4 hp router isn't a requirement for many projects.
Noob is offline
post #9 of 12 (permalink) Old 02-24-2012, 10:59 AM
Default Router Horse Power Dilemma
I have two Bosch 1617 routers, one with a plunge base, the other on a table. I believe they are 2.25 HP. Here's my dilemma. I just purchased a new router table from Woodpeckers. As part of this purchase, I got a lift as well. Woodpeckers makes two lift sizes, the SW350 which I purchased and the SW420. The SW350 can only accomodate 3.5" routers like my 1617s, while the SW420 can accomodate any size router. I may want to make some raised panel doors in the future. I'm not planning to start production of cabinets, just a few for a project I have in mind. Anyway, since the lift is a big investment, I'm wondering if I should look to the future and exchange my small lift for the bigger model, just in case I decide someday that I could benefit from a higher horse power router.
hunterrick1 is offline
post #10 of 12 (permalink) Old 02-24-2012, 01:07 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
I'm no electrician, but when you get to over 20 amps - you may create a new problem. Depending on your shop location, greater HP requires greater amperage - so there can sometimes be some hidden and unexpected costs involved. Good luck. Checking here on the Router Forums is a great step toward an informed decision!
OPG3
Tweak everything!
OPG3 is offline
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
