Best way to trim beadboard - Router Forums
post #1 of 2 (permalink) Old 07-05-2009, 03:32 PM Thread Starter
First Name: Bob
Default Best way to trim beadboard
I installed some beadboard wainscotting for my daughter. The outside corner wall where it starts is a little off vertical and the top lines up with the corner but the bottom sticks out 1/4" or so. I'm going to trim it up before I put the end cap on and am wondering the best way to go about it. The material is hardboard. It seems to me my options are to 1) use the router and a a flush trim bit,which will be pretty messy, 2) use a block plane or 3) use one of those flush trim saws. Any thoughts as to the best way to go? I'm trying to do no damage to the wall so I don't have to repaint it.
rstermer
rstermer is offline
post #2 of 2 (permalink) Old 07-05-2009, 04:15 PM
Hi rstermer
If you have a Dremel tool you can pickup a small saw that will do the job neat and clean..
Dremel 670 Mini Saw Attachment
Amazon.com: Dremel 670 Mini Saw Attachment: Home Improvement
Amazon.com: Dremel 546-01 1-1/4-Inch Diameter Rip/Crosscut Blade: Home Improvement
rstermer
trim router handles earlofroberts General Routing 9 01-15-2008 12:35 PM
Flush trim bits Hamlin Router Bits - Types and Usage 4 12-01-2007 01:51 PM
Which bit for beadboard? Julie Router Bits - Types and Usage 3 08-27-2007 07:15 AM
Where to get a flush trim bit? wanart Router Bits - Types and Usage 4 10-28-2006 08:39 AM
Floor/wall Trim reds_21 General Routing 2 01-13-2006 08:52 PM
