Jointing wide boards - Router Forums
post #1 of 2 (permalink) Old 07-16-2009, 04:35 PM Thread Starter
AxlMyk's Avatar
Default Jointing wide boards
Due to a new project I am starting, it is necessary for me to joint a 9" board on a 6" jointer. Here's how I did it.
First, I cut the board into manageable lengths. I then removed the blade guard from the jointer, and got my push handles ready.
In order to joint wide boards, you need to joint a wide rabbet. This is done easily by running the board down the jointer making as wide a cut as you can. More than half the board width. After I ran the board down 4 times, I lowered the infeed table 1/16" and ran them down a couple more times.
I then took a 5' length of melamine coated board from an old shelving unit and ripped a 6" eide piece off it. The rabbet you just jointed will lay on top of this sled when you put it in the thickness planer.
Run the boards through the planer until the top surface is flat, take the sled away, and turn the boards over to plane the jointed side. When you have removed the rabbet, continue planing until you reach the desired thickness.
AxlMyk is offline
post #2 of 2 (permalink) Old 07-18-2009, 04:37 PM
nzgeordie's Avatar
Ingenious, Mike. One of those "I could have thought of that." (but didn't).
Pete
I've cut it twice and it's still too short! But only at one end.
nzgeordie is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
Jointing long boards Jtomwoods Table-mounted Routing 8 05-25-2008 09:05 PM
buying S4S boards peacefrog Tools and Woodworking 6 10-14-2007 08:53 AM
Router Jointing Drick General Routing 1 12-19-2005 09:21 PM
