Finally Found Another Bandsaw - Router Forums
post #1 of 7 (permalink) Old 07-25-2009, 12:33 AM Thread Starter
RustyW's Avatar
First Name: Rusty
Default Finally Found Another Bandsaw
I have an older 14" bandsaw that only has 5" resaw capacity. A while back I got a riser kit from Grizzly but it would'nt fit without a lot of modification. So I've been searching the internet for what bandsaws the kit will fit. And checking Craigslist 3 or 4 times a day. Well I just got home with a Ridgid BS1400. It's the older gray model and has been wrapped in a tarp under an awning for a few years. I was worried the tires would be shot sitting with the blade on it that long. But the blade was broken and the tires look like new. It was sitting on dirt so the legs have some surface rust and peeled paint, but everything above that is in good shape. He said it was'nt used much and the table is still covered with the big sticker that tells all the features. Tomorrow I'll clean it up and put my riser block on it. All in all I think it was as good deal at $100. Since I think I can recover the money by putting my current one on Craigslist.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #2 of 7 (permalink) Old 07-25-2009, 02:18 AM
$100 sounds like a good deal, Rusty.
What is the make of your older bandsaw?
jw2170 is offline
post #3 of 7 (permalink) Old 07-25-2009, 02:50 AM Thread Starter
RustyW's Avatar
First Name: Rusty
James, my old one is a Ram Machinery. Which is one of many Taiwan imports from the 1980's. It is similar to other 14" saws, and some parts are interchangeable. But everything is 1" smaller than most others (92.5" blade rather than 93.5" and 5" resaw rather than 6").
Rusty
RustyW is offline
post #4 of 7 (permalink) Old 07-25-2009, 03:15 AM
xplorx4's Avatar
First Name: Jerry
Good show getting the new saw. One day I will need to get one. For now untill things clear up we will watch how we spend money!! The next thing I need to get is the dust collector system and finish the downstairs bath room.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 7 (permalink) Old 07-26-2009, 06:37 PM
3efingers's Avatar
I have a small shop so had to settle for the new Jet 10 inch band saw, got it set up and played a little, says it will resaw 4 1/8 inch, I did cut some 3/4 inch oak playing and think I may need to up grade the blade, any suggestions out there?
I got lost in thought. it was unfamiliar territory.
3efingers is offline
post #6 of 7 (permalink) Old 07-27-2009, 12:29 AM
CanuckGal's Avatar
First Name: Deb
The Wood Slicer or Timberwolf blades are recommended for resawing. I use a Swedish Silicon blade (The Little Ripper) from R&D Bandsaws here in Canada and its also an excellent resaw blade.
CanuckGal is offline
post #7 of 7 (permalink) Old 07-27-2009, 06:06 AM
AxlMyk's Avatar
If you have a Woodcraft nearby, I use the Olsen and Timberwolf blades. I can also get the Olsens at a local tool store.
AxlMyk is offline
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
New Bandsaw and Oscillating Sander GoonMan Lobby 3 11-15-2008 12:40 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
I finally have time RGOSSEL New Member Introductions 4 03-06-2008 07:31 PM
Bandsaw advice needed Bob N Tools and Woodworking 7 06-07-2005 03:15 PM
