Drill Press table (need input) - Router Forums
post #1 of 9 (permalink) Old 08-03-2009, 08:21 AM Thread Starter
First Name: Danny
Default Drill Press table (need input)
Hi all:
Hope your weekend was good.
I finally got to do some more work, on the "Great Bird Cage Project" and I ran into an issue of needing more support on the drill press. I was drilling blind holes in the front cage doors for threaded inserts, and I was having a terible time trying to get the hole lined up and support it on the small table on my drill press.
I decided I need to get a bigger table on the drill press, I looked at the ones that Rockler has and I found them kind of pricey for what I was getting, so I decided to make my own.
Im looking for advise on what the table should have, what does and doesn't work, what size is a good workable size, thickness, top material, etc. etc.
While at rockler I purchased the t-slot and hold down kit to use; hold down kit now I just have to build it.
Thanks in advance.
Danny
jd99 is offline
post #2 of 9 (permalink) Old 08-03-2009, 12:52 PM
BigJimAK's Avatar
Originally Posted by jd99 View Post
Hi all:
Thanks in advance.
Danny
Danny,
I too look forward to the responses to your post.
BigJimAK is offline
post #3 of 9 (permalink) Old 08-03-2009, 01:13 PM
Mike Wingate's Avatar
First Name: mike
You will find that a square cutout in the centre of your table useful. Make a set of compatible squares that fit the hole. In some drill holes to give a little clearance for your drum/bobbin sanders. The others will be replaceable inserts for drilling.
Mike Wingate is offline
post #4 of 9 (permalink) Old 08-03-2009, 05:22 PM
curiousgeorge's Avatar
First Name: George
Here is one I made, Danny...
New Drill Press Table
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #5 of 9 (permalink) Old 08-03-2009, 08:14 PM
Bob N's Avatar
First Name: Bob
Here's one I ran up on out in the wild. Looks pretty nice.
Drill Press Table - by rons | LumberJocks.com :: woodworking community
Bob N is offline
post #6 of 9 (permalink) Old 08-04-2009, 07:58 AM Thread Starter
First Name: Danny
Thanks Guys: Thats what I was looking for.
Now I have a question....
George's DP table has the t-track running both directions (front to back, and right to left) the other link from Bob shows the t-track running front to back only.
Does the t- track running right to left get used a lot, or do you find you are using the front to back ones more? (Just trying to figure out if I need to buy intersection)
Danny
jd99 is offline
post #7 of 9 (permalink) Old 08-04-2009, 09:32 AM
Rutabagared's Avatar
First Name: Joe
Originally Posted by BigJimAK View Post
Danny,
So do I. I am also looking for some guidance on general dimensions.
Joe
Rutabagared is offline
post #8 of 9 (permalink) Old 08-04-2009, 09:43 AM
First Name: George
Danny
Danny, I don't think you really need the right to left track. In fact, I can't find the track or intersections at HF. I think maybe the don't carry it any more.
George
Fort Worth, Texas
post #9 of 9 (permalink) Old 08-04-2009, 10:05 AM
Hi George
This is off the point a little bit but you can make your own with the band saw
Or from below
http://www.amazon.com/s/ref=nb_ss_hi...ions&x=18&y=17
http://www.rockler.com/product.cfm?p...er=tee%20track
http://www.rockler.com/product.cfm?p...Select=Details
Name:	TRACK INTERSECTION KIT.jpg
Table for my new drill press. curiousgeorge Show N' Tell 41 11-12-2013 03:38 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
Mini Drill Press - Table jjciesla Jigs and Fixtures 11 04-26-2009 05:10 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 7 07-15-2006 11:20 AM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 3 03-25-2006 10:43 PM
