Which Bandsaw blades? - Router Forums
post #1 of 14 (permalink) Old 08-12-2009, 10:29 PM Thread Starter
First Name: Mike R
Default Which Bandsaw blades?
I need to resaw some various hardwoods into 1/4" boards and cut the top off boxs I make. Also general use in the shop.
The question is what 3 blades would you buy for these uses? could be less then 3 if there is a great all around blade.
I am just starting on the bandsaw and am reading about different TPI and bimetal vs. carbide ect.
I have an older 10" Rockwell with 1/2 HP motor.
Any help is appreciated.
awoodnut is offline
post #2 of 14 (permalink) Old 08-13-2009, 12:53 AM
CanuckGal's Avatar
First Name: Deb
A 3 TPI blade is best for resawing. Timberwolf or Woodslicer blades seem to be the favourites.
A 6 TPI blade is good for general work. If you need smoother cuts consider a 10 TPI blade. If I had to choose 3 blades those would be the 3.
Blade width is dependent on the types of work you are doing and your saw capacity. If you are going to be cutting tight radii consider narrower blades. The wider the blade the harder your saw works. Your saw manual may give you suggestions on blade widths.
I measured, I marked, I cut.
CanuckGal is offline
post #3 of 14 (permalink) Old 08-13-2009, 01:05 PM
Ghidrah's Avatar
First Name: Ronald
The more teeth the slower the push. The difference in the speed of cut between my 6 tpi and 4 tpi (both hook) is obvious.
Ghidrah is offline
post #4 of 14 (permalink) Old 08-13-2009, 02:04 PM
Rutabagared's Avatar
First Name: Joe
Mike,
I've always used the Woodslicer from Highland Hardware. It's a fantastic resaw blade and affordable. This blade is great for ripping and general purpose work as well. It's usually on my bandsaw all the time since I don't use it for cutting tight radius curves very often.
Joe
Rutabagared is offline
post #5 of 14 (permalink) Old 08-16-2009, 10:48 PM Thread Starter
First Name: Mike R
Default Lots of choices
Thanks for the help!
I think I will try a wood slicer and then get a 6 TPI 1/4" to try also.
I am going to try a 1/16" blade to play with when I get some extra cash. Looks like fun on the vidio. Like to try some scroll stuff.
awoodnut is offline
post #6 of 14 (permalink) Old 08-17-2009, 02:20 AM
BigJimAK's Avatar
I've attached a PDF I "printed to PDF" from Suffolk Machinery "did you know". They make Timberwolf blades. On this page they talk about choosing the number of teeth based upon wood thickness.
I've also attached their blade chart.
On their site they recommend calling them for a recommendation on which blade will work best on your saw / motor combination and what you are going to cut. Their web page makes it sound like you'd get to talk with someone who knows blades.
Suffolk Machinery Corp. - Timber Wolf Band Saw Blades
File Type: pdf Silicon-Steel-Carbide-Blade-Selection-Chart-3.12.09[1].pdf (146.2 KB, 70 views)
BigJimAK is offline
post #7 of 14 (permalink) Old 08-17-2009, 11:46 PM Thread Starter
First Name: Mike R
Default Low tension blades
thanks for the links Jim
I hadn't heard of low tension blades. I will do some research on it and I will call the company and pick there brain. I am also going to measure my wheels and ck against the formula.
Have you used these low tension blades and if so what where your results?
Thanks agean
awoodnut is offline
post #8 of 14 (permalink) Old 08-18-2009, 03:32 AM
BigJimAK's Avatar
Mike R & all,
These are Timberwolf blades that people above are talking about, I think?
Please speak out if I've misspoken.
BigJimAK is offline
post #9 of 14 (permalink) Old 08-18-2009, 07:15 AM
AxlMyk's Avatar
Thanks agean
I use a Timberwolf 1/2" 3tpi 105" blade for resawing. The "Flutter method" described on the back of a Timberwolf blade package is the best way to set the tension.
I have never had a cupped resaw yet. I get them at Woodcraft.
AxlMyk is offline
post #10 of 14 (permalink) Old 08-18-2009, 05:05 PM
BigJimAK's Avatar
I just ordered some Timberwolf blades from Suffolk. If it is important to anyone, they accept a check over the phone and ship COD as well as taking bank cards.
BigJimAK is offline
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
Need custom made bandsaw blades Stive Tools and Woodworking 1 06-26-2007 11:39 AM
