Need a quick recommendation......... - Router Forums
post #1 of 15 (permalink) Old 08-13-2009, 11:46 PM Thread Starter
First Name: Duane
Default Need a quick recommendation.........
I have the opportunity to purchase either a brand new in the box Delta 15amp 10" table saw with cast iron table, cast iron wing, extension out feed, no stand. OR a used BT3000 Ryobi with stand, and all attachments.
The Delta is $100 out the door. The Ryobi is $125 out the door.
Which one would be the better saw for both accuracy and durability ?
I know more standard sizes are available for the delta because of the standard miter slots and iron table top but I would like a well versed opinion.
Need to know by Friday night
T/Y
Duane
Duane867 is offline
post #2 of 15 (permalink) Old 08-14-2009, 12:16 AM
AxlMyk's Avatar
Buy them both, try em out, keep one.
AxlMyk is offline
post #3 of 15 (permalink) Old 08-14-2009, 12:18 AM Thread Starter
First Name: Duane
Shhaaa... I wish I could afford to and had the room LOL!
(your sig is killing me over here btw HA HA HA HA HA !! )
Duane867 is offline
post #4 of 15 (permalink) Old 08-14-2009, 04:58 AM
xplorx4's Avatar
First Name: Jerry
You do not say what the model of the Delta is so can't look that one up. What have you read regarding reviews? I have not untill now looked up anything on either saw. Google both and see what folks are saying about them.
Here a couple on the Ryobi
http://www.thewoodworkingcatalog.com...96/ryobi.htmls
The reliable Ryobi BT3000
Lamentations 3:22-23
xplorx4 is offline
post #5 of 15 (permalink) Old 08-14-2009, 05:45 AM
BigJimAK's Avatar
Duane,
I cannot speak to the Delta but I had a BT3000 for about 10 years so I can tell you a few of its strengths and weaknesses.
Strengths:
  • It is a very smooth running machine with no vibration.
  • The rip fence clamped on the front and rear and, once adjusted, did a pretty good job of retaining alignment.
  • It has a sliding table, which is an upgrade even on most high-end saws.
  • The original blade was pretty good but once I upgraded it to a thin-kerf Forrest WoodWorker II it cut through even thick hardwood without bogging down badly.
  • It is belt driven, unlike many of its competitors.
  • It has 3.5" of cutting depth so it will cut 4x4 stock. (I'm unaware of other 10" saws in its class that will)
  • It is light weight and moves easily on its wheeled base but does not move around when you are using it.
  • The dust collection is very good with a shop-vac attached.
  • If you have all of the attachments, you can mount at least some routers under one arm of the saw, giving you a router table.
  • Likewise you can mount a jigsaw in the same extension which emulates a cheap scrollsaw.
Weaknesses:
  • It has a universal motor (like a blender) instead of an induction motor. (The small Delta may too)
  • The table is made of aluminum, so magnetic attachments will not stick.
  • (The one I had) did not have a miter slot, so attachments that use one will not work.
I had it in my 12'x16' "shop", so space was a premium for me then too. It worked well for me.
I only sold it when we were moving back to Alaska and my sweet bride suggested I "sell it and get the Delta Unisaw you've always wanted when we get settled up there". Hence the new table saw in my gagage / shop.
Dang I'm a lucky man, to have such a sweet bride! She knows where the pistol is, knows how to use it and knows where I sleep. Twenty-five years together and she hasn't killed me yet! <g>
BigJimAK is offline
post #6 of 15 (permalink) Old 08-14-2009, 06:28 AM Thread Starter
First Name: Duane
Thanks Jim !
Here is a link to the add for the Delta saw.
DELTA table top saw NEW IN BOX
and one for the Ryobi.
http://cincinnati.craigslist.org/tls/1285080286.html
Duane867 is offline
post #7 of 15 (permalink) Old 08-19-2009, 09:08 PM
Cost control, sirs.
sheridan is offline
post #8 of 15 (permalink) Old 08-19-2009, 09:10 PM
So I think he'd ever tried. haha
sheridan is offline
post #9 of 15 (permalink) Old 08-24-2009, 04:55 PM Thread Starter
First Name: Duane
Ended up buying the Bt3000 and I am of a mind it was the best possible saw for the money I could have bought. LOVE it !
Duane867 is offline
post #10 of 15 (permalink) Old 08-28-2009, 04:00 AM
BigJimAK's Avatar
Just my luck.. I go and post all the things I liked about my BT3000 and somebody local goes and posts one on Craigslist. If I only had the space, it'd make a good second saw!
BigJimAK is offline
Cordless Drill Recommendation CanuckGal Tools and Woodworking 57 08-10-2009 08:59 PM
Quick Change Chuck - Makita?? Rutabegared1 New Member Introductions 4 08-09-2008 09:23 PM
Jig Saw Recommendation rh111 Tools and Woodworking 10 03-20-2007 07:53 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
**New Function** Quick Thread Mark Lobby 1 11-27-2005 09:25 PM
