Climbing, climb cutting - Router Forums
post #1 of 10 (permalink) Old 08-19-2009, 12:18 AM Thread Starter
TWheels's Avatar
Default Climbing, climb cutting
Climbing,or climb cutting is a situation in which the direction of rotation of the cutter in contact with the wood is the same as the direction of movement of the wood. This dituation is very dangerous unless the wood (or whatever material is being cut) is very tightly held in place. Climb cutting can yield cleaner edges that normal cutting. In general climb cutting should be avoided. Climb cutting situations can arise from lack of attention or thought or unclear thought.
This post was intended to be a "discuss this term" in the Word Glossary". On the other hand, it might have a potential for starting a lively discussion.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #2 of 10 (permalink) Old 08-19-2009, 10:00 PM
Tom,
"In general climb cutting should be avoided. Climb cutting situations can arise from lack of attention or thought or unclear thought."
I agree, every time I pick up a router for hand held work, I really have to think about which way to move the router.
jw2170 is offline
post #3 of 10 (permalink) Old 08-20-2009, 11:40 AM
Rutabagared's Avatar
First Name: Joe
Originally Posted by jw2170 View Post
Tom,
James,
Remember - feed as you read.
Joe
Rutabagared is offline
post #4 of 10 (permalink) Old 08-20-2009, 12:37 PM
curiousgeorge's Avatar
First Name: George
Originally Posted by Rutabagared View Post
James,
Joe
Good one! But remember, that is for hand held routing. Table mounted is just the opposite.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #5 of 10 (permalink) Old 08-20-2009, 01:45 PM
BigJimAK's Avatar
"Feed as you read" only works if you are reading the outside of the book.
Still, I like it. It's better than my technique. I think of how I do it on the table and invert it for hand-held. I'll be using your system. Thanks!
BigJimAK is offline
post #6 of 10 (permalink) Old 08-20-2009, 01:55 PM
I use the rule for plunge/hand routers, push it away on the inside pass pull it to you,on the climb cut that I use all the time if I have stock that likes to rip/chip out I do just the opposite but with very light cuts.
" climb cut) The bit will push the stock back into the cut..and keep it from ripping out.......great on the end grain...
post #7 of 10 (permalink) Old 08-20-2009, 08:06 PM
smokey1945's Avatar
First Name: Smokey
Look at "bump cutting" by Charles Neil on U Tube. It really works well.
Smokey
smokey1945 is offline
post #8 of 10 (permalink) Old 08-20-2009, 09:06 PM
First Name: Joe
George and Jim,
Correct. I should have added that, when confused, I envision myself hand routing in front of the router - standing inside the template controlling the router when routing the inside of templates, etc. The direction when table routing has always been intuitive to me but you could envision yourself standing on your head.
Joe
post #9 of 10 (permalink) Old 08-20-2009, 09:24 PM
George and Jim,
Joe
"standing on your head' - now I am confused.......
I just have to remember Gary Rogowsiki routing a mirror frame...
jw2170 is offline
post #10 of 10 (permalink) Old 08-27-2009, 12:10 PM
First Name: Dirk
Hi Ho: Sommerfeld has a neat gadget that is a combination guard and featherboard. He uses it to cut grooves in plywood where tearout would be a problem. The thing provides enough pressure on the router table so that the work piece is trapped and can't be ejected even when climb cutting.
If you want more info, go to his website (the thing is on the cover of the latest catalog) at Sommerfeld's Tools For Wood
I haven't used the thing, but have seen him use it on a DVD.
Let us know what you think. I'm sure some of you have one.
Dirk
dirko is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Cutting groove in cutting board Ken Brown Jigs and Fixtures 7 01-06-2010 09:57 AM
Cutting dados on a router table paulcomi Table-mounted Routing 6 08-05-2006 10:52 PM
