Moisture oozing from lumber - Router Forums
post #1 of 30 (permalink) Old 08-21-2009, 05:49 PM Thread Starter
Ghidrah's Avatar
First Name: Ronald
Default Moisture oozing from lumber
I picked up some PT SYP this aft, carried it down to my shop laid one end of a 8' 2X6 on the roller and the other end on the TS. The bag on the Delta Vac was full so I took it out to empty it. I connected the vac to the TS picked up the PT to start the saw and saw a large deep brown rust profile in the shape of the 2X6.
I dehumidify the shop 24/7 so all the moisture was escaping from the PT. My shop is about 20 cooler than outside, the PT was warm to the touch. I cleaned and coated the table maybe 2 plus months back when I was done reconnecting the motor pulley.
I normally use Nu Finish on my tables but used some older Turtle wax this time. Does Turtle wax go bad after a couple yrs? I freaked out, quickly sprayed the surface with WD40 and used a synthetic sanding sheet to get most of it out then sprayed it again let it set for a bit and sanded it again to bring it back to normal. wiped it with an old cloth and used sawdust to buff it.
I never saw anything like this happen so quickly before.
Ghidrah is offline
post #2 of 30 (permalink) Old 08-21-2009, 07:10 PM
Bob N's Avatar
First Name: Bob
Very common with PT lumber. I hate the stuff!
Bob N is offline
post #3 of 30 (permalink) Old 08-21-2009, 07:56 PM
BigJimAK's Avatar
It's not *only* the moisture, it's wet caustic chemicals!
I won't cut PT on my CI table saw. I used to have an aluminum-topped BT3000 and cut quite a bit of it, for a 12'x24' floating dock, a couple of decks, etc.
BigJimAK is offline
post #4 of 30 (permalink) Old 08-22-2009, 09:12 AM Thread Starter
Ghidrah's Avatar
First Name: Ronald
I come across PT lumber all the time, it's part of my trade, especially when it concerns sundecks. The ACQ PT is supposed to be better than the older CCA PT, chemical wise but not by much, I don't get the reaction to splinters like the older stuff. The quality of the SYP seems to be worse.
Ghidrah is offline
post #5 of 30 (permalink) Old 08-22-2009, 03:44 PM
Hamlin's Avatar
First Name: Ken
This is the problem with PT lumber. You have both the wood moisture plus the caustic chemicals added to it. I let any of my PT lumber sit in the old barn for a yr or two before touching it.
Correct me if I'm wrong but, isn't Turtle wax an auto wax? I see this all the time in the auto sections of any store.
Ken
"A VETERAN"
Hamlin is offline
post #6 of 30 (permalink) Old 08-22-2009, 07:14 PM Thread Starter
Ghidrah's Avatar
First Name: Ronald
I wish I had the luxury of being able to afford thousands of dollars worth of PT that I could sit on in a barn and rotate for proper cooking.
New growth SYP inherently is unstable for most but exterior PT duties due to it's engineered fast growth properties, it rolls, folds, bends twists and mutilates.
I have gotten hold of some old SYP from old revclaimed Boston Brown stone beams that was very nice.
Yes it is car wax, I used to use it strictly till I had a rep from Wood Worker's Warehouse suggest Nu-Finish as a superior protection. I ran out of Nu Finish, still had the Turtle wax so used it.
Yrs ago I noticed that leaving something on the table surface for any extended period would produce the effect even with protection, but never saw that kind of damage after 10 or so minutes a month maybe.
Ghidrah is offline
post #7 of 30 (permalink) Old 08-22-2009, 07:33 PM
AxlMyk's Avatar
Turtle wax is for cars. Furniture wax is for tools. WD40 isn't a rust remover. Try Bar Keepers Friend.
AxlMyk is offline
post #8 of 30 (permalink) Old 08-23-2009, 11:28 AM
Hamlin's Avatar
First Name: Ken
I don't nor will I ever place PT on any of my tables. I cut them with my worm drives/circular saws or jig saw. The left overs go into the barn. I don't even store them anywhere close to my reg. wood pile.
I don't use WD40 for any of my tools. I have several different types of rust protection I use. I usually get them from Grizzly.
Ken
"A VETERAN"
Hamlin is offline
post #9 of 30 (permalink) Old 08-24-2009, 10:39 AM Thread Starter
Ghidrah's Avatar
First Name: Ronald
Axlmyk,
Call WD40 whatever you want, I've found nothing better at loosening the rust from my tables. The synthetic sanding material, close to the dobie pads my wife uses for dishes, (doesn't mar the table surface) in combo with the WD40 removes/lifts the rust from the table. I wipe with old rags till dry then use rubbing alcohol to remove the WD40 then UI use NU-Finish.
I had used Turtle wax for yrs before Nu-Finish with no ill results, I just had to apply it more often. Nu-Finish is also a Car polish, I apply it a couple 3 times a yr. depending on how much work the TS has seen.
Everyone has a modicum of success with many different products, the only thing I've come across with most consensus is to stay away from products using silicon as a component to the wax product because it can transfer the silicon to the wood.
Ghidrah is offline
post #10 of 30 (permalink) Old 08-24-2009, 01:02 PM
nikki1492's Avatar
First Name: Barb
hey to you all,
What is PT lumber? It sound horrid and I want to stay away from it.... but since I don't know what it is....
"Later mon"
Barb
nikki1492 is offline
New to woodworking...where to buy lumber? embo5 Starting Off 14 11-18-2013 09:43 PM
Oak lumber moisture? wyatt earp Starting Off 9 08-20-2008 09:00 AM
HD and their slim choices of lumber.... Hamlin Lobby 6 07-07-2006 04:16 PM
