Broken Clamp Parts - Router Forums
post #1 of 15 (permalink) Old 08-24-2009, 11:11 PM Thread Starter
TRN_Diesel's Avatar
Default Broken Clamp Parts
Can anyone tell me if you can buy replacement parts for these 18" clamps?
The head broke off and there is a wing nut which allows you to take the head off the clamp. I was hoping to buy some more spare heads in case they break again.
Here is a picture of the clamp. The one on the left is broken.
TRN_Diesel is offline
post #2 of 15 (permalink) Old 08-25-2009, 02:26 AM
Mike Wingate's Avatar
First Name: mike
I think you are out of luck. But as 1 door closes, another one opens. If you drill the correct size hole in your bench top of leg, you have an adjustable hold down clamp. Or make a new jaw by laminating one out of 3 layers of plywood.
Mike Wingate is offline
post #3 of 15 (permalink) Old 08-25-2009, 07:58 AM
First Name: Danny
Are they plastic or Aluminum?
I could make one (I think) for you but the shipping would cost more then a new clamp (My Guess).
Ya got access to someone local with a machine shop? You could make them; from the picture it doesn't look like it's too complicated.
jd99 is offline
post #4 of 15 (permalink) Old 08-25-2009, 09:48 AM Thread Starter
TRN_Diesel's Avatar
They are made of plastic hence the reason it broke and was only $12.99 .
post #5 of 15 (permalink) Old 08-25-2009, 09:48 AM
AxlMyk's Avatar
They look like the MIT branded clamps. I have a bunch of those I bought from ACE hardware. Pretty cheap pricing.
I saw a thread on another forum where someone took one and made a bandsaw fence. Mounted one end of the bar in the fence and used the clamp to lock it to the table edge.
AxlMyk is offline
post #6 of 15 (permalink) Old 08-25-2009, 10:03 AM Thread Starter
TRN_Diesel's Avatar
Now Mike your going to get me in trouble because I do not have a Band saw and would have to go out and buy one to make use of the two clamps I have now broken.
Great idea !
Do you have a band saw? If you do what size do you have.. 14" or larger?
post #7 of 15 (permalink) Old 08-25-2009, 10:04 AM
Hi Dan
Many Auto parts stores in the states for 1.50 ea..they have a big box of them from 6" to 24" all at 1.50 ea..' mix or match.. break one and use it for parts
post #8 of 15 (permalink) Old 08-25-2009, 12:09 PM
AxlMyk's Avatar
What ya waitin fer? Go git yerself a bandsaw.
I have a 14" Delta w/riser. One of those Craigslist gems.
Great idea !
AxlMyk is offline
post #9 of 15 (permalink) Old 08-25-2009, 02:48 PM
BigJimAK's Avatar
Mike,
What do you think of your 14" Delta w/riser? I've had one w/o the riser for about 10 years and finally decided to give it a makeover as I'm getting tired of wasting good wood on the planer, planing it to size. I've got a riser kit, timberwolf blades, carter spring, detensioner and rod setup (mine got bent in moving) and a kreg resaw fence in the mail. And yes, its moving just as fast as the "check in the mail"!
BigJimAK is offline
post #10 of 15 (permalink) Old 08-25-2009, 03:02 PM Thread Starter
TRN_Diesel's Avatar
If you had to do it again would you get a 16" Band Saw over a 14"?
If so why or would you go 18" What the most common thing you do with it? I usually like to resaw wood because I buy 8/4 Maple and it is cheaper that way but when I use the tablesaw the blade takes more wood compared to a Bandsaw.
I assume the riser kit allows you to cut wider boards? What is the maximum width board you can cut upright onthe BS?
Parts list to repair unit Al Gardner Tools and Woodworking 3 06-05-2009 10:56 PM
what are the parts to a router bit? allthunbs Router Bits - Types and Usage 25 03-25-2009 06:42 AM
router parts search joromu55 General Routing 3 06-26-2008 08:58 PM
Small Wooden Clamp bobj3 Jigs and Fixtures 0 01-04-2007 05:52 PM
Wanted: Craftsman bandsaw parts list steveo Woodworking Classifieds 4 11-14-2004 10:19 PM
