Dowel hole is too big, now what? - Router Forums
post #1 of 22 (permalink) Old 08-31-2009, 12:07 PM Thread Starter
Default Dowel hole is too big, now what?
So, i have a 1" dowel, and i drilled a 1" hole for a rocking horse handle.
Im not sure what the problem is but either the dowel is less than 1" or the drill bit is more than 1", but the dowel is loose. It does not fit snug. How can I correct this?
agdodge4x4 is offline
post #2 of 22 (permalink) Old 08-31-2009, 12:15 PM
First Name: Duane
How much slop is there and is this made to be removable at a later time or a permanent fixture ?
Duane867 is offline
post #3 of 22 (permalink) Old 08-31-2009, 12:24 PM Thread Starter
enough slop to where the hole will not hold the dowel in by friction, and yes, its supposed to be permanent.
post #4 of 22 (permalink) Old 08-31-2009, 12:41 PM
Many ways to get it to fit,,if you have a Japanese hand saw you cut a slot in the center of the dowel and drive in a thin wedge in,brass works well.
Or wrap it will some thick paper,the paper will take up the slop and it's real hard to see it after..
Note....most all the dowels are under size.
post #5 of 22 (permalink) Old 08-31-2009, 12:48 PM Thread Starter
ha! Duh....i dont know why I did not think of splitting it and putting a wedge in it! Thanks for the tip, i will try it. Im not very experienced in wood working. I had thought of putting paper around it, but didnt know if that would be good enough. I suppose it would be, it will be glued and paper is made of wood...so why not.
Thanks again!
post #6 of 22 (permalink) Old 08-31-2009, 12:53 PM
First Name: Duane
I would have just glued it, but then there would probably have been a visible seem some where huh ?
Duane867 is offline
post #7 of 22 (permalink) Old 08-31-2009, 01:03 PM
Hi
The paper will hold ,,soak the paper with glue tap it in the hole and wipe the glue off with some white vinegar and bottle water, a spray bottle works well, a 50/50 mix will clean the glue off...so you don't get that nasty blotch mark from the glue that likes to seal the wood
Thanks again!
post #8 of 22 (permalink) Old 08-31-2009, 02:29 PM
First Name: Duane
I should clarify.... I meant I would have just glued it as is with no paper.
But I'm a newbie so... LOL !
Duane867 is offline
post #9 of 22 (permalink) Old 08-31-2009, 02:32 PM
Hi Duane
" But I'm a newbie "
Me too
post #10 of 22 (permalink) Old 08-31-2009, 02:38 PM
xplorx4's Avatar
First Name: Jerry
BJ if your a newbie I am in serious trouble!!
Lamentations 3:22-23
xplorx4 is offline
Room divider finished jigger Jiggers Gallery 17 09-26-2011 11:05 PM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 07:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 04:29 PM
