Flush cut? - Router Forums
post #1 of 13 (permalink) Old 08-31-2009, 12:57 PM Thread Starter
Default Flush cut?
Part of the project I am working on for this rocking horse requires two pieces to be glued together. The body is cut from two identical patterns and then glued together. Since i cut them out separately, they obviously arent exactly the same and when glued the edges are not flush. Some parts of one side are shorter than the other and vice versa. Each side it 1.5" thick, so a flush cut router bit wont really do the trick. I dont think they make one long enough. So, whats teh best way to get the two side flush on the edges? Just sand it like crazy?
agdodge4x4 is offline
post #2 of 13 (permalink) Old 08-31-2009, 01:10 PM
Hi
If you don't have the LONG router bit they make ( 4" long),make a 1/4" thick ,template,use it for the pattern for both,(use double sided carpet tape ) then use the trim bit to get them both right on..
post #3 of 13 (permalink) Old 08-31-2009, 01:33 PM Thread Starter
that 4" bit would be the ticket if I could get it in 1/4" shank. I havent seen one that long at home depot or lowes. Ill have to get it online?
post #4 of 13 (permalink) Old 08-31-2009, 01:41 PM
HI
Should stick with the 1/2" shank size,that's a lot of mass to spin but they do make a 1/4" shank size also,but you must take with it ,very small cuts
eBay Store - Super Carbide Tools: Single bit, 2 pc Set, Set
http://cgi.ebay.com/1-pc-1-4-SH-3-Bl...4.c0.m14.l1262
post #5 of 13 (permalink) Old 08-31-2009, 02:03 PM Thread Starter
well, really, i only need to trim at max 1.5" at a time of poplar. So a 2" would be more than enough.
post #6 of 13 (permalink) Old 08-31-2009, 04:41 PM
Sounds great Jason
Don't forget the thickest of the template (1/4' to 1/2" thick MDF,it's easy to sand out the little nicks left by the band saw blade ) ,with just a little bit more on the bit
post #7 of 13 (permalink) Old 08-31-2009, 04:48 PM
Gene Howe's Avatar
First Name: Gene
Couldn't you trim one side with a 2" bit and template then, flip it over and follow the just routed edge with the same bit?
I'd for sure use a 1/2" shank bit!
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #8 of 13 (permalink) Old 09-01-2009, 12:44 PM Thread Starter
Thats fine, but its hard to get that 1/2" shank into the 1/4" collar on my router.
post #9 of 13 (permalink) Old 09-01-2009, 01:16 PM
Hi Jason
You can pickup the item below and chuck it up in your lathe and turn it down to 1/4" but that's if you have a lathe.. then you can use 1/2" shank router bits in your router..note***but I don't recommend using the big bits with this setup..
Just one more way to skin the cat..
#9465
Router Collet Extension and review
post #10 of 13 (permalink) Old 09-01-2009, 03:39 PM
BigJimAK's Avatar
Hi Jason
You pickup the item below and chuck it up in your lathe and turn it down to 1/4" but that's if you have a lathe.. then you can use 1/2" shank router bits in your router..note***but I don't recommend using the big bits with this setup..
#9465
BJ... Either that or pick up your router, chuck it in your lathe and ream the collet out to 1/2"...
BigJimAK is offline
flush trim bit question blurry Router Bits - Types and Usage 0 01-21-2009 11:36 PM
Flush trim bit not flush RuggerJoe Router Bits - Types and Usage 8 03-19-2008 12:57 PM
Flush trim bits Hamlin Router Bits - Types and Usage 4 12-01-2007 01:51 PM
Flush Trim Bit? cbsjoez1935 Router Bits - Types and Usage 5 07-28-2007 11:35 AM
Where to get a flush trim bit? wanart Router Bits - Types and Usage 4 10-28-2006 08:39 AM
