tablesaw sled - Router Forums
post #1 of 6 (permalink) Old 09-03-2009, 06:20 AM Thread Starter
Thumbs down tablesaw sled
I want to build or buy a table saw sled for my Ryobi BT 3000 but dont know if one can be attached to it as it does not have the 2 -3/" grooves in the table saw platform-I am wondering if anyone out there has a solution for me?
Arnie Juhnke is offline
post #2 of 6 (permalink) Old 09-03-2009, 07:34 AM
Julie's Avatar
First Name: Julie
Are there no grooves for a miter gauge?
~Julie~
Julie is offline
post #3 of 6 (permalink) Old 09-03-2009, 07:48 AM
First Name: Danny
I thought the BT 3000 already had a sled.
jd99 is offline
post #4 of 6 (permalink) Old 09-03-2009, 07:53 AM
kp91's Avatar
First Name: Doug
The saw has a sliding table.........
Set the miter fence up so it just clears the blade by about 3/4 inch, add a long MDF sacrificial fence taller than the stock you're cutting so that you have support behind your piece and you should be good to go.
If you really have to use a sled, you can make one that stradles the center table of the saw.
The guys at BT3central have tips for making miter guage slots and other jigs.
http://www.bt3central.com/index.php?...es#Traditional Table Saw Jigs - BT3 Style
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 6 (permalink) Old 09-11-2009, 02:02 PM
dutchman 46's Avatar
First Name: Howard
Hello Arnie! I hope you don't mind me asking about the sliding miter table? It is a great unite. If you don't have one, check on BT3000, and you will find help on there. My own BT3000 has a sliding miter, and it is as accurate as it can be. It is a good idea to have a home built sliding unite to cut plywood that is longer than the smt can handle.
John 3:16
dutchman 46 is offline
post #6 of 6 (permalink) Old 09-11-2009, 02:50 PM
TRN_Diesel's Avatar
Post a picture of your Table saw from a few different angles and let see what we can do to help you.
TRN_Diesel is offline
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 10:14 AM
Table saw sled.......... Duane867 Tools and Woodworking 5 07-29-2009 07:59 PM
A version of Mr. Nixon's CC Super Sled Ghidrah Show N' Tell 6 04-17-2009 02:08 PM
TS sled for all seasons simplenik Tools and Woodworking 4 06-18-2007 08:23 AM
Crosscut sled - diffefent way to make it simplenik Tools and Woodworking 8 05-29-2007 09:02 AM
