Is this safe?? - Router Forums
post #1 of 2 (permalink) Old 09-15-2009, 05:33 PM Thread Starter
Question Is this safe??
I got a new saw in the other day, Ryobi BTS 21. Been making my zero clearance inserts which is kinda a trick on that saw.
Problem was when I went to make an insert for the shaper head, the spindle is awful short. I can only get 8 flats of turn on the nut by hand and probably another flat with the wrench. The plate is 3/8" thick with a 5/16" spacer to get the cutters away from the motor far enough. I could probably go to a 1/4" spacer, but not much less. Don't even know where I could get one anyway. I could probably build up a optimum spacer with fender washers but don't feel real comfortable with those either.
Any suggestions or am I just being a little anal retentive about this?
John Schaben
jschaben is offline
post #2 of 2 (permalink) Old 10-25-2009, 07:48 PM
dutchman 46's Avatar
First Name: Howard
I haven't had any experience with that,John, but if you could post a few pictures, it might help with making a desision.
John 3:16
dutchman 46 is offline
A safe router table Mike Shop Safety 6 07-19-2009 10:40 PM
Safe coping Joe T Table-mounted Routing 1 08-08-2008 08:33 PM
Proper method - want to be safe Dennis Davis Table-mounted Routing 3 02-01-2008 08:25 PM
Pie Safe for kitchen DougW Show N' Tell 8 01-10-2007 11:00 PM
Safe Speed of 1 5/8" dia. bit...? Joe Lyddon Router Bits - Types and Usage 2 10-02-2006 09:17 AM
