Question about equipment - Router Forums
post #1 of 2 (permalink) Old 09-19-2009, 05:29 AM Thread Starter
Default Question about equipment
Well, hello, Guys.
I'm new to routing - that's first of all.
And, off course, encountered some "problems".
1. Need "circling jig" - a "trammel unit" for my DeWalt 621 (to make plywood round plates of about 10-30 cm radius) - any advices...
P.S.:For Festool the unit-alike is SZ-OF1000.
2. I'm going to fix-up Makita 3612C in a workbench (that is just 1" - width plywood plate) - any ideas-advices 'bout how-to.
Thanx in adv.
tr00 is offline
post #2 of 2 (permalink) Old 09-19-2009, 09:13 AM
derek willis's Avatar
First Name: Derek
Dennis,
Make yourself a false baseplate such as the attached picture, this will be screwed to the base of your router, then with a pin through into timber turn and cut.
Should you want to make without a centre pinhole, then still make a template this way and then stick to another piece and rout with a pattern bit with a bearing guide, you can then make as many as you wish.
An even simpler one can be found if you scroll through my gallery.
Derek
derek willis is offline
ANOTHER!?!?!? Dovetail Question... Skipdog Jigs and Fixtures 13 05-08-2009 09:42 AM
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 08:23 AM
Very Rookie Question Schu4598 General Routing 8 11-15-2005 08:42 AM
