drill press-what size? - Router Forums
post #1 of 15 (permalink) Old 09-22-2009, 09:20 PM Thread Starter
First Name: Trevor
Default drill press-what size?
Recently I have been wishing that I had a drill press. I have two milwaukee drills-corded and cordless. Occasionally I could use the accuracy of a drill press.
This summer has been chaotic and I have only been in my shop a couple of times. With fall/winter coming I plan on starting a few projects.
I look online and see all different types of drill presses. I am torn between the 15" ridgid-floor model and a smaller 10 or 12" benchtop model like a craftsman.
Space is kind of at a premium due to my new Harley taking up its own corner of the shop :-) So a benchtop is looking attractive-something I can use and then store on a shelf somewhere.
However for a littlle more money I can get a larger more powerful drill press in a stationary.
So my question is: for most applications that everybody does on a daily basis in there woodworking shops-would a 10" DP do it, or is it really worth getting the 15" floormodel with a larger shop footprint?
I want something that I can drill wood/plastic/aluminum/some metal with.
jeep_man is offline
post #2 of 15 (permalink) Old 09-22-2009, 09:48 PM
xplorx4's Avatar
First Name: Jerry
I just recently got the Ridgid 15" floor model. How I went so long without the DP I am not sure. I use it all the time and on occasion I have used nearly all of the vertical room it has. Whether you get the Ridgid or some other model you will not regret getting the floor mount. I have had mine nearly a month I think??
Lamentations 3:22-23
xplorx4 is offline
post #3 of 15 (permalink) Old 09-22-2009, 10:10 PM
Hi Trevor
You can have the best of both worlds by thinking out side the box so to speak..
You can mount the drill press backwards on the table top ,that's to say have the head of the drill press hang over the edge of the table top,,then you can use it like a floor model,the head on all drill presses just slip over the column and it can be locked in to place anywhere...
post #4 of 15 (permalink) Old 09-22-2009, 10:15 PM
kp91's Avatar
First Name: Doug
I have an 8 inch bench top, WAY TO SMALL. Still waiting for the right replacement to come along.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #5 of 15 (permalink) Old 09-22-2009, 11:13 PM
CanuckGal's Avatar
First Name: Deb
I gave up the bench model for a floor model. Even in my limited space shop it was worth it!
I measured, I marked, I cut.
CanuckGal is offline
post #6 of 15 (permalink) Old 09-23-2009, 06:31 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Trevor
Oooh ! Love the pink dearie! Seriously, though, who on earth thinks pink is a good colour for a tool ? I'd better rephrase that, too! OK, what are the two small pink knobs just above the chuck for?
I like the idea of mounting the drill so that I can swing it round for greater clearance under the chuck.
I wanted a floor mounted one, but all the ones I saw here were 3phase 440v jobs and the cost of getting one, then remotoring and switching it, wasn't worth while, so I've opted for a cheap bench model for the time being. It's coped with everything so far.
Cheers
Peter
istracpsboss is offline
post #7 of 15 (permalink) Old 09-23-2009, 09:52 AM
curiousgeorge's Avatar
First Name: George
My suggestion would be to get the biggest and best you can afford at the time. Space and price wise. The cheaper the tool the more it will cost in the long run when you have to replace it later. Just think about it... After you have replaced a cheap tool two or three times, you could have gotten the top of the line to start with.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #8 of 15 (permalink) Old 09-23-2009, 10:09 AM
Hi Peter
" two small pink knobs just above the chuck for?"
That's the red lazer cross hair lines...(lights)
Craftsman 12 in. Drill Press
You can make a floor model easy with some steel pipe and a flange or two ( weld on type or screw on type) then make a base cabinet on wheels to pull out of the way when you need the floor model
Cheers
Peter
Name:	craftsman base plate a.jpg
Name:	craftsman base plate b.jpg
Name:	craftsman base plate c.jpg
post #9 of 15 (permalink) Old 09-23-2009, 10:57 AM
xplorx4's Avatar
First Name: Jerry
BJ very nice drill press, I take it it is a bench mount correct?
xplorx4 is offline
post #10 of 15 (permalink) Old 09-23-2009, 11:04 AM
Hi Jerry
Thanks,,bench model, yep like most shops I don't have the room for the floor model, but I do use the work around when I need one,,it's no big deal to flip it around and re bolt it down..
I have been thinking of doing that to the Jet drill press in the background but I just don't need to use it that way most of the time...
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
Drill Press table (need input) jd99 Tools and Woodworking 8 08-04-2009 10:05 AM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
