Bandsaw variable speed vs 1 speed - Router Forums
post #1 of 33 (permalink) Old 09-24-2009, 09:41 PM Thread Starter
TRN_Diesel's Avatar
Default Bandsaw variable speed vs 1 speed
I have started to research Bandsaws (BS) and have it narrowed down to the 16" 1 speed by Craftex Busy Bee Tools Product Detail and the 18" Craftex Busy Bee Tools Product Detail.
Can anyone please tell me the advantage of having a variable speed on the BS? IS this a big deal because I sure could save a few dollars by having the 16" CT082 model.
TRN_Diesel is offline
post #2 of 33 (permalink) Old 09-24-2009, 11:01 PM
xplorx4's Avatar
First Name: Jerry
Hey Dan I was going to write something cute but---if you can go for the gold get the very best you can afford and you won't regret it later. I am really looking forward to seeing your shop when you are done and just getting ready to start your first project in it. Happy building, happy buying,
Lamentations 3:22-23
xplorx4 is offline
post #3 of 33 (permalink) Old 09-25-2009, 03:19 AM
curiousgeorge's Avatar
First Name: George
Dan,
Variable speed is almost a necessity on a band saw as far as I'm concerned. You need different speeds for different woods and size of blades as well as in re-sawing. As you use the band saw you will come to understand why variable speeds are necessary, trust me. I think you will be disappointed in the future with a single speed. It's cheaper in the long run to buy the best you can afford in the first place.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 33 (permalink) Old 09-25-2009, 03:27 AM
BigJimAK's Avatar
I'm curious too, Dan. I just put a riser on my 14" Delta and am still tuning it but am curious.
BigJimAK is offline
post #5 of 33 (permalink) Old 09-25-2009, 06:02 AM
AxlMyk's Avatar
I have never, nor seen a need, to change the speed of my bandsaw.
My 14" Delta with riser is set for fast, and stays there.
The only tool that I change speed on is the drill press.
AxlMyk is offline
post #6 of 33 (permalink) Old 09-25-2009, 08:05 AM
First Name: Danny
I know variable speed is important in cutting steel/metal but I didn't think it was that important on wood, I know my Band saw has two speeds but I can't comment on if I change speeds or not since it is still in the box, and I haven't had a chance to set it up yet.
jd99 is offline
post #7 of 33 (permalink) Old 09-25-2009, 08:22 AM
Bob N's Avatar
First Name: Bob
Dan,
I would think a single speed will work just fine if all you are going to cut is wood. The optional speed is mainly for switch over to metal cutting. I am not one for trying to cut both on the same saw.
Bob N is offline
post #8 of 33 (permalink) Old 09-25-2009, 08:31 AM Thread Starter
TRN_Diesel's Avatar
Originally Posted by curiousgeorge View Post
Dan,
I understand with a router you need to control the speed while using different size bits on wood and how hard the wood is but not so sure when cutting wood on a BS.
When you buy different blades do they recommend what speed to run them at depending on the species of wood?
Thanks for the replies to date I really appreciate the input and comments.
post #9 of 33 (permalink) Old 09-25-2009, 12:24 PM
First Name: George
Dan,
The different speeds have to do with the type of blade (tooth rake, blade size, etc.) and density of wood you are using and the ability of the blade to clear the saw dust from the cut. If the blade can't clear the cut it will either bog down, not cut straight, not cut well, overheat and break or all of the above. For instance; if you notice the blade is having a hard time cutting while re-sawing, you may try a different speed and it will improve the cut or stop the blade from wandering. There is a reason for variable speed on a band saw for cutting wood and not just cutting metal. I have yet to see a "speed chart" for the band saw. It is more of what works best for you at that particular situation at that particular time. You just have to experiment and find out what works best and when. Pretty much the same as with a router.
Here is a podcast you may want to look at ...
Podcast #22: Buying & Getting the Most Out of Your Band Saw — Woodworking Online
As in all power tools, there is more to it than just putting it together and turning it on.
George
Fort Worth, Texas
post #10 of 33 (permalink) Old 09-25-2009, 12:55 PM
i cant imagine the need for different speeds but i dont have that much experience using one
does the variable speed slow things down real low? i know cutting metal you want slow speeds so maybe really dense wood would need slow speeds as well?
Mike Gager is offline
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 10:38 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Variable speed routers MichaelT General Routing 10 02-24-2009 12:46 PM
rule of thumb for variable speed? rprice54 General Routing 3 01-11-2006 05:50 PM
variable speed routing Dean VV Table-mounted Routing 3 03-23-2005 10:12 AM
