Old vices - Router Forums
post #1 of 6 (permalink) Old 09-25-2009, 02:47 AM Thread Starter
First Name: Mike R
Default Old vices
Hello
I was given these two vices years ago. Never used them but now I have a use for them.
I want to mount one of them but not shure if one model is better then the other and for what reason. Pictures are attached and any advice would be appreciated. One seems to close ageanst the edge of the bench and the other has two jaws.
I am planning to mount them under my work bench which is 1 1/8" plywood. I will probably put in a wood spacer to get them down flush with top of bench.
awoodnut is offline
post #2 of 6 (permalink) Old 09-25-2009, 05:56 AM
Bob N's Avatar
First Name: Bob
Hi Mike,
I would use the one in the far right pictures. It has a jaw that will attach to the apron of your bench and offer more support.
Bob N is offline
post #3 of 6 (permalink) Old 09-25-2009, 01:22 PM
Hamlin's Avatar
First Name: Ken
Hi Mike,
IMHO, use both. Place one on each end of your bench.
Ken
"A VETERAN"
Hamlin is offline
post #4 of 6 (permalink) Old 09-26-2009, 12:09 PM
dutchman 46's Avatar
First Name: Howard
Hello Mike, Welcome Now is the time to take them apart and clean, and paint, or power coat the painted metal. Get the bars nice and shiney. I would use the right one as a main vice, and mount the other on the side. Both should do a good job as long as the screw and bars aren't bent
John 3:16
dutchman 46 is offline
post #5 of 6 (permalink) Old 09-26-2009, 01:20 PM Thread Starter
First Name: Mike R
Default In good shape
Hello
The bars and screws all appear to be in good shape and they are just oily. Looks like they where greased at one time.
Do you need to grease this type of vice?
I only have room to mount one now. I will probably make a rolling table in the future and mount the other on that some day.
Need to use it to try hand cut dovetails.
Thanks for the help.
awoodnut is offline
post #6 of 6 (permalink) Old 10-18-2009, 12:26 PM
First Name: Howard
I do not believe it necessary to grease them, but, i would also assume that it will reduce wear that will occur. If you do, keep it to lightly You don't need any oils on your work. I am sorry it took so long for a answer, I don't often get a chance just to scroll through the post, I hope it does help. Thanks
John 3:16
