How to mount a band saw blade - Router Forums
post #1 of 6 (permalink) Old 09-30-2009, 05:00 PM Thread Starter
RealCom's Avatar
First Name: Ralph
Default How to mount a band saw blade
Hi guys,
I have and older Craftsman Bandsaw and I am tying to moiunt a new blade. When I try to run a piece thouhg it the blade slips off the pulleys. Any suggestion will be appreciated.
RealCom is offline
post #2 of 6 (permalink) Old 09-30-2009, 05:18 PM
Hi RealCom
This is what I do..
Once I put the blade on, and it's unplugged ,I move the top pulley by hand and move the adjustment knob in or out to get it to track on the center on the wheel, once it's on center I plug it back in and run for a quick on and off to make sure it running true on the top and and the bottom wheel, then unplug it for one more time and check the guide bearing/rub blocks to make sure they are set right, if so I move it by hand one more time and check the blade to make sure it's set right and it's tight to get the sweet ping from the blade with my finger nail...if it right then I put on the blades covers and plug it back in,then run it for just quick spin to make sure it running true, then run some hardwood and recheck the blade one more time..if all things are set I'm good for the next time I want to use it..
Originally Posted by RealCom View Post
Hi guys,
post #3 of 6 (permalink) Old 09-30-2009, 06:49 PM
kp91's Avatar
First Name: Doug
Take a look at the tires, it may be time to replace them.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 6 (permalink) Old 09-30-2009, 07:19 PM
AlanZ's Avatar
First Name: Alan
Does your bandsaw have two or three wheels?
If it's an old 3 wheel design, I found that using some masking tape to affix the band temporarily to the upper wheel helped me wrangle the rest of the blade around the other two wheels and the guides.
Fussing with this configuration made me realize very quickly that I wanted a two wheel machine. So now I have a 14" Delta with a riser block... an enormous step up from my introduction to band saws.
Triton 2.25 router; CMT Industrio table; Jointech fence; SC planer; Dewalt miter; Delta 14" bandsaw; Festool TS55, MFT/3, CT22, ETS150/3, OF1400, PSB300EQ; Dewalt Scrollsaw; Lathes: Nova DVR XP, Delta 46-460; JJ-6CS jointer, Ridgid OSS; Grizzly 1023s cabinetsaw
AlanZ is offline
post #5 of 6 (permalink) Old 09-30-2009, 08:13 PM
First Name: Paul
Hi guys,
Does it come off the front or rear of the wheels?
Paul
Minichillo's Construction
Website One Man Shop
I will never leave you hanging!
MinConst is offline
post #6 of 6 (permalink) Old 12-13-2009, 02:09 PM Thread Starter
RealCom's Avatar
First Name: Ralph
Sorry it took so long to get back to you.
Thanks guys for all your suggestions. I took BOBJ3 instructions and it work out great.
Thanks again for everbody's help.
RealCom is offline
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
Forrestt II thin kerf blade Birch Tools and Woodworking 22 04-11-2009 11:59 AM
10" blade selection?? jeep_man Tools and Woodworking 27 04-10-2009 04:57 PM
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 4 04-10-2009 12:27 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
