Skiis for planing wide surfaces - Router Forums
post #1 of 5 (permalink) Old 10-05-2009, 02:19 AM Thread Starter
BigJimAK's Avatar
Default Skiis for planing wide surfaces
I've been planning on building some router skiis for some time. This weekend I've been working on a prototype for a cherry bench with tapers (picture 2 from October 2009 FWW), M+T's, 1-3/4" finished thicknesses, etc. so I'm making the prototype out of 2x10's. I'd run some 2x10's through my planer and table saw to get them flat and square but when I glued four of them together (2 thick x 2 wide) there was a little bit of warping (no surprise, since it was construction-grade (wet) lumber. Lacking a jointer plane or a 20" power planer, I started out flattening them with my belt sander, with mixed results. Then I built a set of skiis for my 3hp plunge router, installed a 1" bit and used it to flatten the slabs. It worked great! Now the sanding will be needed just to remove roughness.
I've attached some pictures.
Jim
BigJimAK is offline
post #2 of 5 (permalink) Old 10-05-2009, 03:41 AM
xplorx4's Avatar
First Name: Jerry
Jim does the router have any sage in the center? What size rod did you use? I like you TS, how about a photo tour of your shop some time?
Jim
Lamentations 3:22-23
xplorx4 is offline
post #3 of 5 (permalink) Old 10-05-2009, 04:36 AM
Bob N's Avatar
First Name: Bob
Nice job Jim. The skis are an excellent accessory to the router in so many ways.
Bob N is offline
post #4 of 5 (permalink) Old 10-05-2009, 04:57 AM
xplorx4's Avatar
First Name: Jerry
What will I need to purchace to build a set??
xplorx4 is offline
post #5 of 5 (permalink) Old 10-05-2009, 05:46 AM
Bob N's Avatar
First Name: Bob
Some threaded rod, washers, wing nuts and 2 small pieces of 3/4" MDF is all. Maybe around $6 or so.
Bob N is offline
Jointing wide boards AxlMyk Tools and Woodworking 1 07-18-2009 04:37 PM
