Tablesaw zero clearance inserts for free! - Router Forums
post #1 of 21 (permalink) Old 10-15-2009, 12:03 PM Thread Starter
First Name: Harry
Default Tablesaw zero clearance inserts for free!
With the price of everything going up, I look for ways to save a buck whenever I can. We all know how nice zero clearance inserts are in our table saws. Deltaís MSRP for their Model 36-862 insert is $84.99, but you can find them for $30-$40. In either case thatís a lot. I use to make them from plywood but they didnít last long. I made a few from aluminum, but not everyone has a machine shop and the price of aluminum is going up all the time, plus metal will rattle in cheaper saws.
I now have as many as I need, for nothing, or $.60 if you donít have any setscrews around. Only takes about 30-40 minutes to make one.
Most cabinet shops have large amounts of sink cutouts. Corian, is the kind to ask for. There are other solid surface materials, such as Capresa, but I personally donít know how well they will machine. Most shops will give you as much as you can haul for nothing. I did find a couple shops that wanted a couple dollars each for them, which is still a good deal; but if you look, you can get them for free, especially if you explain to them that they are for shop use, and not for resale.
The images below show how I do it:
1. Typical cutout, they come in all colors, shapes and sizes. They are about Ĺ inch thick.
2. Use 2-sided tape to hold the cutout in place on the old insert. Remember to remove any screws, etc. that could interfere with the guide bearing.
3. Cut to size, using your pattern bit. DC helps, as the chips are light and stick to everything.
4. Drill setscrew holes and finger hole. I use ľ-28 setscrews, because I have a bunch of them, just about any size between 10-32 and ľ -28 will work.
5. Tap the setscrew holes and soften all edges. I use a 1/8-inch round over bit.
6. If your saw blade will not lower enough for the insert to fit; tape it to your old one, turn on saw and slowly raise the blade, just enough to break the surface.
Separate the inserts, and clean them, I use acetone to remove any residue left by the 2-sided tape. Polish with 1000 grit as much as you feel you need to.
7. One in my Delta.
Notes: None of my saws are the same. One is longer and my Craftsman uses a thinner insert, so I have to either plane down the Corian or just cut a rabbet along each side.
Iím told any of the solid surface counter top material will work; but I havenít used any thing but Corian, so be safe, always check whatever you are going to use; can it be machined.
Harry, TX
Cut it twice, and it's still too short!
Old_Chipper is offline
post #2 of 21 (permalink) Old 10-15-2009, 12:37 PM
Bob N's Avatar
First Name: Bob
Harry, what a great idea/tip.
Thanks for the post!
Bob N is offline
post #3 of 21 (permalink) Old 10-15-2009, 12:57 PM
Hi Harry
Very nice show and tell , well done
7. One in my Delta.
post #4 of 21 (permalink) Old 10-15-2009, 01:43 PM
Question How thin can ya go?
Hi Harry - Great idea. Been making mine out of plastic cutting boards. About 6 bucks ea but I could get two, for my old saw. This saw only has a 1/16" ledge around it. Plastic doesn't get it here, I don't think. I like the idea of corian if there is any strength left to it at that thickness.
Managed to get a Zero insert farm engineered together but for the dado cutter and molding head been trying to figure out how to do 16 gauge steel without any sheet metal tools.
Upside is that the blade throat is rectangular, not oval.
John Schaben
jschaben is offline
post #5 of 21 (permalink) Old 10-15-2009, 02:52 PM
Hi John
I do the same and have the same error as you do ,I also use the UHMW stock that is very tough stuff..
What Is UHMW?
(Ultra High Molecular Weight Polyethylene)
Characteristics:
* The highest abrasion resistance
* Outstanding impact strength even at low temperatures
* Excellent sliding material due to low coefficient of friction
* Self-lubricating
UHMW Plastic Sheets and Strips
post #6 of 21 (permalink) Old 10-15-2009, 03:19 PM Thread Starter
First Name: Harry
thanks John,
Now that's a strange one, never saw one like it before. Strange pattern, looks like flooring. What brand is it?
John, I think alumimun would work for you. It would be strong enough(?)maybe and you could work it with hand tools. Really all you would need is a good Hacksaw, couple of good files. The straight cuts you could do with the tablesaw on metal that thin. You would need a carbide blade at least a 100 tooth. If you were to use a course blade the teeth would grab it, with nasty results. I would sandwich it between some 1/2" plywood, that would be the safe way. You sure it's 1/16 that's only .062 ? I believe I would reinforce the un-supported edge with 1/4 aluminum angle, you could pop rivet it together. Any way you could modify the table to take a thicker insert. Wish you were nearby, bet I could come up with something better.
Harry, TX
post #7 of 21 (permalink) Old 10-15-2009, 07:30 PM
xplorx4's Avatar
First Name: Jerry
That is a great way to get rhe material, thanks.
Lamentations 3:22-23
xplorx4 is offline
post #8 of 21 (permalink) Old 10-15-2009, 08:29 PM
BigJimAK's Avatar
7. One in my Delta.
This is a great idea, Harry. I've been considering making so for my new TS but was hoping for something heavier than wood.
Next I need to study the existing throat plate to see if there's a good way to retain use of my new Uni's riving knife while operating zero clearange. It will require a blind slit in the plate behind the blade so must be cut in advance. Hmm.. Maybe that 1/8" router bit I've got on order from Ptree, in my RT will do it. Hmmm...
BigJimAK is offline
post #9 of 21 (permalink) Old 10-16-2009, 01:22 AM
Talking
thanks John,
Hi Harry, that's the Ryobi BTS21. The pattern you see is on the mitre table. Being pretty well stuck with contractor saws because of space constraints so I got this one to alleviate my biggest safety issue with contractor saws, namely lack of work area on my side of the blade. Most of them anything more than 7" or so and you have a balancing act on your hands for crosscuts. The mitre table eliminates that, I can get a good 14 or 15" supported out there. But it also comes with it's own set of problems. No mitre slots at all. I didn't expect one on the left, but it doesn't have one on the right either. Put a very nice Incra V120 out of a job, at least for now. The long mitre fence is nice, although I have already lopped off one of the plastic endpieces.. hehehehe,, guess Ryobi was expecting that.
Anyway, table insert is 1/16th, I put the calipers to it. I cabbaged the zero insert by marrying a piece of 20 gauge aluminum angle iron with a hunk of 3/8 polyethelene cutting board. Works OK but doesn't look good. Will likely do it over sometime. It is nice in that the riving knife comes over the back of the machine so no issues with that and the Zero Insert.
With the dado blade I doubt there will be much of an insert at all. I don't think I will be able to get any more than a 3/4" dado stacked because the spindle is so short, also not much space in there anyway. I haven't really put the dado blade on there to see where I am yet but I did load the molding head once. It's the front and back of the molding head that needs the support, especially the front. I tried it with a makeshift insert and one of those big honkin cutters yanked the stock right into the throat. I suspected it was gonna do that so I was prepared for it.
I bought a metal cutting blade for a 7-1/4" saw, 5/8 arbor. I think I'll screw the 16 gauge steel to a piece of 3/4 ply, set the blade just higher than 1/16 and run the assembly face down on the table saw to at least get length and width. I can make the cut out with a jigsaw and die grinder. Seems like the safest way.
Oh well, first pic is the mitre table, second with version 1.0 of the table insert. Last is the open throat.
Thanks guys....
Name:	mitre table.JPG
Name:	zero insert.JPG
John Schaben
jschaben is offline
post #10 of 21 (permalink) Old 10-16-2009, 03:53 AM Thread Starter
First Name: Harry
thanks for posting more pictures. I can see it has some nice features. Is the Orange insert, the factory one? Looks like it wasn't designed to use a dado set. Had a little Wards TS 50 years ago that was like that. Be careful if you try cutting the sheet metal, You can risk cutting alumimun, but steel is a lot more dangerous.
Harry, TX
Zero clearance fence inserts Bogydave Table-mounted Routing 31 08-27-2011 02:06 PM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 09:08 AM
Old Rockler aluminum mounting plate inserts Mike Table-mounted Routing 0 07-07-2009 09:57 PM
guide to making zero clearance inserts ZCI blurry Tools and Woodworking 12 03-01-2009 11:13 PM
TS zero clearance inserts Router is still my name Tools and Woodworking 1 06-13-2008 12:39 AM
