Rust prevention on Tools - Router Forums
post #1 of 12 (permalink) Old 10-16-2009, 11:43 AM Thread Starter
First Name: Dennis
Default Rust prevention on Tools
I recently bought a used table saw on Craigs List. It had an iron top which had rust that I cleaned up.
Now I am wondering the best thing to prevent the rust, but not stain any wood I cut in the future.
What have others done for rust prevention on cast iron work surfaces?
Dennis
farrout is offline
post #2 of 12 (permalink) Old 10-16-2009, 11:58 AM
BigJimAK's Avatar
Johnsons Paste Wax (yes, the stuff thats been around *forever*) has a large following... as does Boeshield... I have traditionally used Boeshield but have picked up some Johnsons and am going to run my own mini-test by redoing some of my cast iron in each and monitoring the performance. I'm in no way dissatisfied with Boeshield; I'm just curious to run a comparison. Others will offer additional alternatives.
One sure thing about Johnsons; one can will last a lifetime unless you're running a commercial shop. Probably even then!!
BigJimAK is offline
post #3 of 12 (permalink) Old 10-16-2009, 01:09 PM
First Name: Mark
Default Johnson's Paste Wax
Dennis
I use Johnson's Paste Wax. It works great, you can find it anywhere and it is inexpensive.
AVman is offline
post #4 of 12 (permalink) Old 10-16-2009, 01:47 PM
First Name: Harry
HI Dennis,
I take it a step farther, once I remove the rust, I sand it with 400G, clean it with alcohol, then apply gun bluing. Bass Pro sells the large bottles. This leaves a very nice finish, like a new saw. Since it is a chemical reaction, is it part of the metal and don’t rub off.
Then I use the wax. Little more work, but will last 5-6 years.
Harry, TX
Cut it twice, and it's still too short!
Old_Chipper is offline
post #5 of 12 (permalink) Old 10-16-2009, 04:13 PM
BigJimAK's Avatar
Originally Posted by Old_Chipper View Post
HI Dennis,
I take it a step farther, once I remove the rust, I sand it with 400G, clean it with alcohol, then apply gun bluing. Bass Pro sells the large bottles. This leaves a very nice finish, like a new saw. Since it is a chemical reaction, is it part of the metal and donít rub off.
Is that the source of the loud BOOMs I hear coming from your shop, Harry?
BigJimAK is offline
post #6 of 12 (permalink) Old 10-16-2009, 04:43 PM
curiousgeorge's Avatar
First Name: George
Johnson's Paste Wax hands down. As said previously, a can lasts forever, it's way cheaper than anything else, the surface is super slick and it does not cause any problems with your wood. The only caveat is that you have to apply it correctly. Just apply a good coat and be certain to let it dry before buffing it off. Just one coat is needed because every time you apply a new coat it removes the previous. If you apply a coat every week or so (depending on how much you use your saw) you should have no problems with your saw table rusting. Oh! Yeah! I almost forgot. DON'T EVEN THINK ABOUT USING AUTO PASTE WAX. That stuff will get on your wood and ruin your finish.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #7 of 12 (permalink) Old 10-17-2009, 01:24 AM
crquack's Avatar
Interesting.
We cannot get Johnson's Paste Wax in Canada so I use Trewax. I suspect they are similar - a bit of carnauba wax with additions.
Trewax recommend at least two coats which has been my practice (I use three on bare metal). I was able to demonstrate that a single coat provided very little rust protection.
In all honesty I have not repeated the test with the three coats. I am planning to do a comparison test of several protective agents but it is not a high priority right now
crquack is offline
post #8 of 12 (permalink) Old 09-21-2011, 12:19 PM
First Name: Dave
Default rust prevention
Hi Dennis,
I have heard that Johnsons paste wax works pretty well. I have the same problem with rust you had. How did you get rid of the rust?
Thanks,
Dave
dkelley99 is offline
post #9 of 12 (permalink) Old 09-21-2011, 12:48 PM
xplorx4's Avatar
First Name: Jerry
Past wax works for me, need to do mine today,
Lamentations 3:22-23
xplorx4 is offline
post #10 of 12 (permalink) Old 09-21-2011, 09:44 PM
The Warthog's Avatar
First Name: Roger
I used Minwax paste wax. It makes the top nice and slippery to allow you to slide your workpieces on the surface, too. I also use it on my MDF router table. And occasionally to finish furniture projects.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
Quality vs Cheap tools Jennabutala Tools and Woodworking 37 08-15-2016 06:58 AM
help me set small shop, tools, layout ect... Mimielam Starting Off 24 08-08-2009 01:47 PM
Which tools for most jobs Bob N Tools and Woodworking 11 02-23-2009 12:04 PM
Some turning tools that I made Mitch12 Woodturning and Lathes 16 11-15-2008 10:29 PM
