Dead Bandsaw - Router Forums
post #1 of 6 (permalink) Old 10-17-2009, 07:08 AM Thread Starter
Mike Wingate's Avatar
First Name: mike
Default Dead Bandsaw
I turned on my Startrite bandsaw, and it just went clunk. No movement of the motor or blade. I have checked the fuse and plug. both ok. The cable is fine from the plug to the connector within the bandsaw. How do I determine where the problem is. It could be the motor, starter capacitor or the on/off switch. I have common sense and a multimeter. I can strip down the switch unit, but how do you check for a burnt out motor or starter capacitor?
Mike Wingate is offline
post #2 of 6 (permalink) Old 10-17-2009, 08:02 AM
Hamlin's Avatar
First Name: Ken
Hi Mike,
Check the brushes first. Blow out the motor if need be. I use a multimeter myself when checking motors, capacitor's and such. Sometimes, even the motor themselves have a circuit breaker on them, this may have tripped. Again, some do, some don't.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 6 (permalink) Old 10-18-2009, 12:37 PM
dutchman 46's Avatar
First Name: Howard
Is the motor enclosed, or does it have any slots, for something to get in. It may be worth a check!
John 3:16
dutchman 46 is offline
post #4 of 6 (permalink) Old 10-20-2009, 03:40 PM Thread Starter
First Name: mike
Checked out. The contactor coil in the on switch has failed. A new one is on order.
post #5 of 6 (permalink) Old 10-20-2009, 04:04 PM
Bob N's Avatar
First Name: Bob
You're a good detective Mike! A cheap and easy fix..... good work.
Bob N is offline
post #6 of 6 (permalink) Old 10-20-2009, 06:01 PM
xplorx4's Avatar
First Name: Jerry
I wish I had a band saw to resurrect!!
Lamentations 3:22-23
xplorx4 is offline
New Hitachi Bandsaw NewMontanaWorkshop Tools and Woodworking 15 03-08-2010 11:38 PM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
New Bandsaw In The Shop.... challagan Tools and Woodworking 23 10-22-2007 12:53 PM
Bandsaw advice needed Bob N Tools and Woodworking 7 06-07-2005 03:15 PM
