Window cutout - Router Forums
post #1 of 2 (permalink) Old 10-21-2009, 11:27 AM Thread Starter
Default Window cutout
I have a piece of 9 x 12 hardwood stock 1" thick into which I need to cut a 6 . 9 window. It is important that the sides of the cut be straight and the angles accurate. I've tried my hand-held jigsaw but the result is too sloppy. What would you recommend for tool and technique?
fishlore is offline
post #2 of 2 (permalink) Old 10-21-2009, 01:11 PM
Hi Bill
The router is great tool for that job,,you just need to make a quick template,,many ways to do that that, the real easy one is the same way you cut out the hole for a router mounting plate in a router table , but this time you would use your brass guides to keep the router running true inside of the template..
Here's a easy way to make a template..
Tips_20
Garage Overall for Shop TRN_Diesel Workshop Showroom 558 10-24-2010 02:44 PM
Window Construction jschaben DIY and Renovation 7 12-05-2009 03:13 PM
Window Trim Detail TRN_Diesel Show N' Tell 10 10-23-2009 10:34 PM
replacement window mullion wyndham6 New Member Introductions 3 12-16-2008 01:35 AM
installing baseboard and window trim [email protected] The Finishing Touch 3 01-02-2006 09:28 AM
