Setting Jointer knives - Router Forums
post #1 of 14 (permalink) Old 10-26-2009, 07:46 AM Thread Starter
First Name: Danny
Default Setting Jointer knives
I finally got around to unpacking that Jointer I bought from HF a couple of months ago got it all assembled, and put on the mobile base.
Then I started checking everything, and for the most part everything is close enough for my work. but the knives were way out of adjustment. Long story short; it took the better part of an hour for me to get those knives set and straight to the table.
Is there any tricks or set up tool that you all use to set up your jointer?
Danny
jd99 is offline
post #2 of 14 (permalink) Old 10-26-2009, 09:58 AM
First Name: Roman
Jointer pal is designed to hold the knives at the right height while you tighten down. Available at most woodworking stores. Available in plastic and metal. If you use carbide knives it will not work, just for the normal steel knives.
romanf is offline
post #3 of 14 (permalink) Old 10-26-2009, 10:02 AM
First Name: Daniel
See this thread for more input: http://www.routerforums.com/tools-wo...ting-tool.html
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
post #4 of 14 (permalink) Old 10-26-2009, 11:55 AM
I use a good dial indicator setup and that makes it a bunch easier for me. Of course 30-some years of practice helps some also... Once you get the hang of it setting straight knives does get easier and faster so hang in there.
I have a story on my site about setting straight jointer knives if reading someting and looking at pictures might help. See the link below. At least it gives you a break before going back....that helps me also.
http://www.newwoodworker.com/setjntknives.html
Tom Hintz, Publisher
NewWoodworker.com
Tom Hintz is offline
post #5 of 14 (permalink) Old 10-26-2009, 01:33 PM Thread Starter
First Name: Danny
The link doesn't work
jd99 is offline
post #6 of 14 (permalink) Old 10-26-2009, 01:44 PM
curiousgeorge's Avatar
First Name: George
It worked for me. Nice site, by the way.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #7 of 14 (permalink) Old 10-26-2009, 01:47 PM
dutchman 46's Avatar
First Name: Howard
I just tried it, and it worked for me, Try again
John 3:16
dutchman 46 is offline
post #8 of 14 (permalink) Old 10-26-2009, 02:40 PM
drasbell's Avatar
hmm I just tried the link and I get this
Service Unavailable
HTTP Error 503. The service is unavailable.
Life: Is a runaway train you cant wait to get on.
drasbell is offline
post #9 of 14 (permalink) Old 10-26-2009, 03:24 PM
CanuckGal's Avatar
First Name: Deb
Yep it's working!
I measured, I marked, I cut.
CanuckGal is offline
post #10 of 14 (permalink) Old 10-26-2009, 07:04 PM
drasbell's Avatar
Must have been my ISP cuz now its working....
drasbell is offline
Freud knives for Jet jj-6csx jointer? AxlMyk Tools and Woodworking 10 04-10-2010 05:04 AM
Jointer problems Hamlin Tools and Woodworking 5 11-11-2007 03:29 PM
Installing jointer knives - Help - Old 4" Joe Lyddon Tools and Woodworking 4 10-20-2007 10:54 AM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
Jointer blade setting tools? reible Tools and Woodworking 6 03-11-2005 08:58 PM
