Resawing - Router Forums
post #1 of 14 (permalink) Old 10-29-2009, 09:40 AM Thread Starter
First Name: Mark
Default Resawing
Ok guys/gals,
I am researching for my future projects and what I am finding is that 8/4 lumber is just $2 more that 4/4. It seems to me that ordering the 8/4 is more economical that the 4/4 and resawing the 8/4. I have a 3hp 19" Grizzly BS on the way so resawing should not be an issue. I am just wondering if it is worth the extra effort of resawing for the money. By the way most of my projects will be furniture. What kinds of blades are being used with success in resawing? Your experiences are appreciated.
AVman is offline
post #2 of 14 (permalink) Old 10-29-2009, 09:53 AM
Bob N's Avatar
First Name: Bob
Call these folks for an absolute authoritive answer to your question.
I have used them for years and they have always been most helpful and taken good care of my needs.
Suffolk Machinery Corp. - Timber Wolf Band Saw Blades
Bob N is offline
post #3 of 14 (permalink) Old 10-29-2009, 11:49 AM
curiousgeorge's Avatar
First Name: George
Ditto on the Timber Wolf blades. They are awesome and tend to last a lot longer because they are a low tension blade, which is better for the blade and your saw.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is online now
post #4 of 14 (permalink) Old 10-29-2009, 12:12 PM
AxlMyk's Avatar
+2 on TW blades. I use a 1/2" 3tpi in my Delta 14" and it does a great job.
Use the flutter method to tension them.
AxlMyk is offline
post #5 of 14 (permalink) Old 10-29-2009, 12:58 PM
Hi Guys
Talking about band saws and blades, I just got a Band Saw Stabilizer® all I can say is WOW,,it's great and they make some great blades and well,,Peachtree is now selling the line also..
Band Saw Stabilizer® by Carter Products
Carter Bandsaw Stabilizer
Carter Accuright Band Saw Blades
post #6 of 14 (permalink) Old 10-29-2009, 01:33 PM
First Name: Danny
Hi Guys
Glad to hear the stabilizer works, I received mine but it wouldn't fit the Craftsman saw as they thought. Sears changed the 12" guides to the same guides as the 14" so I had to return and am waiting on the right one.
jd99 is offline
post #7 of 14 (permalink) Old 10-29-2009, 01:42 PM
Hi Danny
Thanks for the heads up by the way..
I do alot of scroll work but it's has a draw back ,can't cut thick stock but now I can I was amaze it would work as well as the scroll saw but it does ,I cut a 4" thick block like it was 1/2" thick stock,I used a 1/8" blade and it was as clean as the scroll saw AND TRUE.. all I say is WOW, ONE MORE TIME
post #8 of 14 (permalink) Old 10-29-2009, 02:29 PM
BigJimAK's Avatar
+3 on TW blades. If you're curious about which type to get, give Suffolk Machinery (google it), the manufacturer of TW and ask them. I've talked with them in the past and their people really know there stuff andwill not only give you a recommendation based upon the properties of the wood (hard vs. soft, thickness range and green vs dry) but they'll give you the reasons why.
BigJimAK is offline
post #9 of 14 (permalink) Old 10-29-2009, 03:11 PM
First Name: George
Hi Guys
I bought one of those last year for my Shopsmith band saw and they do work, but only on small blades for making sharp turning cuts. They are not for use with large re-saw type blades.
George
Fort Worth, Texas
post #10 of 14 (permalink) Old 10-29-2009, 03:19 PM
Hi George
I have used the 1/8" ,1/4". and the 3/8" blades and it works on all of them..they say for the blades 1/4" and the 1/8" but I was amazed it work on the 3/8" just as well..
I always push the bounders the 1/2" /3pt. blade is my next list to try,should work because the blade 1/2" ,should help it running true..time will tell.. I have a 3/4" blade but I think that maybe pushing to far..
Band Saw vs Scroll Saw? kolias Tools and Woodworking 42 05-14-2009 05:43 AM
Bandsaw Question jarhead165 Starting Off 6 01-24-2006 06:47 PM
