compound miter angles - Router Forums
post #1 of 5 (permalink) Old 11-07-2009, 10:05 PM Thread Starter
First Name: Glenn
Default compound miter angles
I am building a buggy seat 2 sides and a back the sides and back are both at a 30 degree angle from the seat. My question is how do I figure out the miter and bevel angles ?
gdemo is offline
post #2 of 5 (permalink) Old 11-16-2009, 09:33 PM
To get a 30 degree angle you divide the angle In two. Each side would be cut at 15 degrees. When joined together you have a 30 degree corner.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 5 (permalink) Old 11-16-2009, 09:47 PM
If your not sure of the exact angle. You can always use a sliding Bevel gauge
then just transfer your angle..
Not sure if this is the right info that your looking for.
Mt-Pockets is offline
post #4 of 5 (permalink) Old 11-18-2009, 12:31 PM
Ghidrah's Avatar
First Name: Ronald
You have a little bit of hip roof framing going on here and that's a bit complicated.
What you need is the angles for the saw cuts which requires much dimensional information, i.e., runs and rises of the material.
There's a non math option, I'd make a set of, (1/4 or 1/2) scaled test pieces 1st, to minimize waste. Take some scrap plywood, and draw 1/2 your seat backer with the 30 on 1 side and do the same for one of the side pieces. Rip the 30 along the bottom, (plate cut) of both pieces take the cut offs from the side cuts and use them to prop up the backer and piece at 30. The 30 side angles will be cut back later, they're always less than the 30.
Use a framing square, plywood or some other thing to create a 90 right angle, (pseudo seat) so you can slide the 2 pieces together at 90. When the tops, of the 2 pieces touch, (ridge cut) mark the bottoms of both pieces where they stop along the 90 corner.
1. Measure this distance off the 90 corner to the marks made, e.g, (X) = 3/4".
2. At a 90 angle measure (X) off from the point where the backer and side piece touched, (ridge cut) and mark both pieces.
3. Strike a line from the bottom, (plate cut) to and through (X), (new ridge cut)
4. Use speed square or whatever you have to discover the new angle
5. Cut new angle into both pieces and test on 90 corner, should line up perfectly for butt joint.
I'd go with a butt joint for screwage, if you're going for a miter cut it should be at or very close to 45
Ghidrah is offline
post #5 of 5 (permalink) Old 11-23-2009, 03:40 AM Thread Starter
First Name: Glenn
Thanks Ghidrah, very helpful!
gdemo is offline
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
Compound Angles reible Tools and Woodworking 2 03-28-2005 01:34 AM
