finishing raised panels - Router Forums
post #1 of 10 (permalink) Old 11-10-2009, 04:47 PM Thread Starter
First Name: Vaughn
Default finishing raised panels
I am making a blanket chest for my DIL for Christmas. The design calls for flat panels, but I wanted to try out my new raised panel bit set, so I milled them to size as raised panels.
Question: the design says to finish the panels with stain before putting them in the frame so you don't get unstained streaks from expansion, etc., and then cover them with wax paper as you mount them in the frame to protect them when you stain the rest of the chest.
That sounds pretty complicated, and I doubt it will work with raised panels. How do you guys finish your raised panel doors? How do you keep from streaking the panel with stain once it's mounted in the frame?
Fanaticism is always a sign of repressed doubt...Carl Jung
Padawan Learner is offline
post #2 of 10 (permalink) Old 11-10-2009, 05:23 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 10 (permalink) Old 11-10-2009, 05:51 PM
It depends on how steady you are. As I get older I tend to finish parts then assemble. I also will use a sanding sealer then after assembly do a final coat.
vikingcraftsman is offline
post #4 of 10 (permalink) Old 11-10-2009, 06:25 PM
Hi Vaughn
Many stain the panels b/4 assemble but most of the time they are stain the same as the frames..
If I was going to make it diff. I would stain the panels 1st.then set them to one side and then stain the frame b/4 glue up, once it's dry ,glue up the parts and then put the clear coat on all the parts after dry up..you will want to do a dry fit b/4 anything, you will not get a 2nd. chance..for any sanding you may need to do..
You can use some white vingar and some bottle water ( 50/50 mix in a spray bottle) to wipe up the glue if you have some come out of the joints..
but do it right away do let have a chance to seal the wood..
I would not use wax paper, it's not the wax paper it's the masking tape that will give you the error..almost all tape will leave something behind that will seal the wood..
that wil give you that funny look in the corners..
post #5 of 10 (permalink) Old 11-10-2009, 11:50 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
You can use some white vinegar and some bottle water ( 50/50 mix in a spray bottle) to wipe up the glue if you have some come out of the joints..
That's one I'd not come across before. Is that a PVA solvent? Most of our vinegar here is either grape or apple based rather than brewed. I wonder if it would make a difference?
Cheers
Peter
(Learning something new every day)
istracpsboss is offline
post #6 of 10 (permalink) Old 11-11-2009, 03:09 AM
BigJimAK's Avatar
* I would not use wax paper, it's not the wax paper it's the masking tape that will give you the error..almost all tape will leave something behind that will seal the wood..
BJ, would you have the same problem if you used blue painters tape?
BigJimAK is offline
post #7 of 10 (permalink) Old 11-11-2009, 08:28 AM
Hi Peter
" PVA solvent?" Not to sure, but you get white clear vinegar in the food store..I should say in the states..in a small plastic bottle or a gal.bottle..
Cheers
Peter
post #8 of 10 (permalink) Old 11-11-2009, 08:37 AM
Hi Jim
Tape is tape...it all as glue on it ,the blue stuff works great over painted items BUT..glue is glue..I have found out the blue stuff does not seal real well on the edges of the tape..not to bad for spray jobs BUT..wipe on stuff it will let it bleed ...under the tape..
post #9 of 10 (permalink) Old 11-11-2009, 10:28 AM
Julie's Avatar
First Name: Julie
Finish AND clear coat your panels, not your stiles and rails. When they are completely dry, put them in the frames and put green tape on the finished panel edges where they meet the stiles and rails. Glue up. I find I always have to sand the frames, as careful as I am about fitting them precisely, I always need to sand them and often leave them slightly oversized so that I can trim them to fit after the glue up. Then finish your staining, leaving the tape on the panels.
Years ago I made some panel doors and did not finish the panels first. The panels did shrink and the line between the panel and the frame is NOT a pretty sight. Live and learn!
~Julie~
Julie is offline
post #10 of 10 (permalink) Old 11-11-2009, 03:36 PM
BigJimAK's Avatar
Thanks, BJ..
Hi Jim
BigJimAK is offline
Question on raised panels kylawyer Table-mounted Routing 8 03-24-2011 12:29 PM
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
Raised panels CanuckBeaver Tools and Woodworking 3 10-20-2005 12:27 PM
