Harbor Freight Clamp Upgrade - Router Forums
post #1 of 7 (permalink) Old 11-16-2009, 07:38 PM Thread Starter
First Name: Danny
Default Harbor Freight Clamp Upgrade
I purchase the $1.99 clamps from harbor freight every so often and I figure that if I break one then it's not a big loss. But here lately it seems that they are breaking on the first use, and it's not the heads that are breaking off, but the handles comming out of the base.
I took the cover off and found out what is going on so here is what I did to fix/upgrade the clamps.
Hope this help some of you if you use the same clamps and the handle comes off.
jd99 is offline
post #2 of 7 (permalink) Old 11-16-2009, 08:09 PM
Nice fix Danny
Problem I been having with those is they get to where they aren't tightening up. Haven't had time to tear one apart yet... still in my "to-do" pile.
John Schaben
jschaben is offline
post #3 of 7 (permalink) Old 11-16-2009, 08:30 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
I had one break also Danny. I drilled mine out and put in a roll pin. Problem solved.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 7 (permalink) Old 11-17-2009, 02:30 AM
xplorx4's Avatar
First Name: Jerry
Good info, maybe I will do that before it is a problem like during a glue-up or something.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 7 (permalink) Old 11-23-2009, 10:00 PM
First Name: Duane
I can never get mine to clamp hard enough to hold a glue joint.
Duane867 is offline
post #6 of 7 (permalink) Old 11-24-2009, 07:33 AM Thread Starter
First Name: Danny
I have one of the last 4 I bought that is like that, I haven't had time to take it apart yet to see why, when I do if I find the fix I will post it.
The rest are fine I have about 8-9 total that are good except for the handle's breaking.
jd99 is offline
post #7 of 7 (permalink) Old 11-24-2009, 10:00 AM
Ghidrah's Avatar
First Name: Ronald
I have 4" Bessy ratcheting clamps, that had similar trouble, the hinge screw nuts on 3 of the clamps kept unscrewing. I permatexed them, (gasket sealer)
Ghidrah is offline
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 10:40 PM
Broken Clamp Parts TRN_Diesel Tools and Woodworking 14 08-26-2009 06:07 AM
Bora Clamp edge Hamlin Tool Reviews 9 04-15-2009 11:55 AM
Clamp-All Clamp Set bobj3 Jigs and Fixtures 14 02-28-2008 08:40 PM
Pipe Clamp question ryan.s Tools and Woodworking 7 03-20-2005 03:41 PM
