Ridgid BS14000 bandsaw? - Router Forums
post #1 of 4 (permalink) Old 11-19-2009, 10:24 PM Thread Starter
Default Ridgid BS14000 bandsaw?
I have an opportunity to pick up a used Ridgid BS 14000 bandsaw. It is gray, not the orange that is now offered. Does anyone have any experience with this saw? And how does it compare with the new one. Any info would be appreciated. Thanks.
bygolly is offline
post #2 of 4 (permalink) Old 11-19-2009, 11:12 PM
RustyW's Avatar
First Name: Rusty
Mike, I have one I picked up for $100. All the reviews on the HD site are right on. Theres a lot of vibration and the 3/4 hp motor is a little under powered. I took it off the legs, built a wooden rolling base,and switched to a better belt. All that helps the vibration, but doesn't eliminate it. The grizzly riser kit fits, I have it on my saw right now. Although it's kind of pointless with the small motor. Other than that, everything is easy to adjust, and it tracks real well, even with the riser block. I'm going to keep tinkering with this one until I find something better. Or Try a bigger motor, if I can scrounge one up somewhere. I read somewhere that the 14000 (as opposed) to the 1400, was the first model with the lifetime warranty.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #3 of 4 (permalink) Old 11-20-2009, 03:39 AM Thread Starter
Thank you for the info.
bygolly is offline
post #4 of 4 (permalink) Old 11-20-2009, 09:45 AM
xplorx4's Avatar
First Name: Jerry
That would not be my first choice because of the vibration problem. I have nothing against Ridgid, I have their TS 3560, drill press, oscillating sander and duel base router, I like Ridgid tools just not this one. I did read that Ridgid was up-grading their bandsaw, but you are asking about an older one. Just went back and looked at the price, go buy it you can get a better one later.
Lamentations 3:22-23
xplorx4 is offline
Ridgid Belt/spindle sander EB4424 kp91 Tool Reviews 18 04-28-2015 10:06 PM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
Ridgid, Bosch, or Other? MinorHero General Routing 2 06-12-2009 04:20 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
