Dremel Tool Precision Router Base - Router Forums
post #1 of 8 (permalink) Old 12-05-2009, 12:01 AM Thread Starter
BigJimAK's Avatar
Default Dremel Tool Precision Router Base
I was parsing one of my WW books and came across an article on using the Dremel as a router. I was somewhat surprised as I've handled Dremel's plunge base and, to be nice, I'd call it a "low-tolerance device", at least the one I saw. The plus side was it was relatively inexpensive for a plunge base ??19.99??
Additionally, the Dremel is a very versatile tool but doesn't have a lot of "muscle", compared with the Trend. Nevertheless, I read on. The article was focused on very small-bit routering, as you would find in making fine musical instruments.
The introduced me to the Steward-MacDonald (SM) base. SM specializes in tools for luthiers. The base is ~$50 and they offer a kit adding an air pump, brass edge guide and binding router bit for $100. In both cases, the Dremel is not included.
I'm not a luthier and have no other current need for small-scale routing today but thought others might so am passing it along.
Here's the URL..
Precision Router Base at Stewart-MacDonald
BigJimAK is offline
post #2 of 8 (permalink) Old 12-05-2009, 02:48 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
It's very cute Jim, I can see a use for it routing freehand signs on boxes, something like this one which is laser engraved.
Harry
harrysin is offline
post #3 of 8 (permalink) Old 12-05-2009, 03:16 AM
xplorx4's Avatar
First Name: Jerry
Nice looking equipment, will made.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 8 (permalink) Old 12-05-2009, 06:44 AM
Bob N's Avatar
First Name: Bob
A great looking little device for the purpose. Please note that it NOT truly a plunge base though.
Bob N is offline
post #5 of 8 (permalink) Old 12-05-2009, 08:50 AM
Gene Howe's Avatar
First Name: Gene
Too many options!
Sooner or later, I'm going to scratch build some "N" gauge buildings and other scenic elements. Was thinking of the Trend unit, but this looks good, too.
Anybody have any advice?
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #6 of 8 (permalink) Old 12-05-2009, 10:20 AM
Hi Gene
Stick with the Trent. it can take on the 1/8" shank bits and the 1/4" bits as well.
Originally Posted by Gene Howe View Post
Too many options!
post #7 of 8 (permalink) Old 12-05-2009, 11:48 AM
First Name: Duane
I think you could achieve the same results with the cheapy plastic grout removal, engraving shroud with depth setting. I'll take a pic of mine tonight.
It just screws on the end as well. Fits B&D and dremel.
Duane867 is offline
post #8 of 8 (permalink) Old 02-08-2010, 02:51 AM
Jim Onkka's Avatar
It's used for routing channels for inlays to fit in. Mother of pearl or abalone shell cut into intricate patterns. Usually found in top of the line string instrument necks. I often use a 1/16" bit in mine.
Jim Onkka is offline
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Can't Find Craftsman Router Base Plate DucatiTorrey Portable Routing 4 11-06-2009 08:52 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
Replacing Router Base Weekendwoodworker General Routing 1 05-02-2008 04:55 PM
dewalt 621 router base Dimitri Guest General Routing 5 10-05-2004 08:15 PM
